Thread: IBT heat load
12-06-2009, 07:30 AM #1
IBT heat load
Can anyone help me to calculate the total heat load / hour of an ice bank tank working on direct feed of ammonia. Total length of ammonia coil is 1800 m & dia is 32 mm. Temp. inside tube i.e. ammonia is around -7 deg C and outside temp i.e. water is around 0 deg C. Chilled water pumps are 2 nos. of capacity 80,000 LPH.
12-06-2009, 12:36 PM #2
Re: IBT heat load
Hi MAKU,
What do you really to know? The heat transfer capacity from the water to the coil OR the cooling needs of the "cold water consumers" (services). It's a different thing, special if the purpose of the ice bank is accumulate ice for the peak heat load hours.
RegardsTo make progress is never good enough, I want to do better and better and better
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Heat transfer coefficient - Coolpack
By Graham in forum FundamentalsReplies: 10Last Post: 28-05-2008, 01:08 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM
