Thread: brema ice maker problem
01-04-2009, 06:48 AM #1
i have a brema ice maker i am working on the refrigeration part works fine when it goes on to harvest is has hot gas defrost and the works fine but it does not move on to the next faze in the cycle i tested timer motor it has three thermostats bin thermostat evap thermostat witch think is ok becasue it moves on to harvest i and a thermo for defrost temp not shore it if it the timer or one of the thermostats i was thinking motor towords timer getting stuck or defrost thermostat i have not done much work on this brand of ice makers does any one have i wiring diagram for a brema cb1565aq and could any one tell me witch thermostats are make on rise and brake on rise so i can test them
01-04-2009, 06:49 AM #2
Re: brema ice maker problem
the evap heats up but is sticks on harvet 4 ever
01-04-2009, 06:52 AM #3
parts manual would be good and best place to bye parts for them in australia
02-04-2009, 10:16 PM #4
sounds to me like you have a timer problem. dats from experience of bremas which are pretty good machines
05-04-2009, 08:15 PM #5
hi
there is a 3 pin thermostat try to make timer motor work dy making a jumper between the brown &grey 1 as i recall if it didnt move its a timer problem if it moves its a thermostat problem
15-08-2010, 01:55 PM #6
For parts try Ice Master on 03 9455 2300 they have most bits you need in stock and can give you fault-finding advice over the phone.
01-08-2011, 01:35 AM #7
24-08-2010, 01:26 AM #8
on a brema ice machine how can u get 120 volts on both sides of the harvest coil when its a 120 volt system. i advance the defrost timer. and timer moves through defrost and stops. and thats when i get 120 volts on both sides of harvest coil. and get 130 degree temperature gas going into evaporator coil.
25-08-2010, 09:41 AM #9
Amana refrigerator/ice maker problem
By SCStewart in forum Trouble ShootingReplies: 6Last Post: 08-08-2010, 10:50 PM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 05:00 PM -
Polar t315 ice maker problem
By nutfielder in forum DomesticReplies: 3Last Post: 29-12-2008, 08:16 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM -
Scotsman Dc33pa Ice Maker Troubleshooting
By Sean LaDart in forum Trouble ShootingReplies: 8Last Post: 13-02-2006, 09:01 PM
