Thread: Black Fuses
    Apr 2006
    Canada
    48
    152
    13
    Black Fuses
    We have a System, who tripped the main disconnect.
    When opened, all the compressor fuses (12) were blown and fuse holder and fuses are blackened by arcing.
    We still havn't checked the compressors.
    Any suggestions / ideas??
    70
    10,602
    52
    Re: Black Fuses
    Loose fuses, moisture, fuses pulled when under load.
    Apr 2008
    united states
    54
    29
    Re: Black Fuses
    It sounds like a major arc fault with no fuse cordination. nfpa 70e covers the dangers of an arc fault.
    Auckland
    68
    3,362
    32
    Re: Black Fuses
    Could have been caused by a voltage sag/ brown out, definitly check motor windings/ power isolated of course. Meggar test windings to ground and each winding test with ohm meter, with motor leads disconnected at motor.
    Alternatively the motor was drawing overcurrent and fuses are under rated and flashed over between phases. Dust and gunge can trigger a flash over, moisture will add to problem.
    magoo
  1. Thermal fuses
    By paul_h in forum Electrical
    Last Post: 11-09-2008, 11:37 AM
  2. Black Oil
    By mebluna in forum Hydrocarbons
    Last Post: 18-08-2007, 11:45 PM
