30-03-2009, 10:19 PM #1
thermo king tesco unit fault door code
hi have a client with a second hand tesco reefer sb3 unit shutting down, fault showing [door] in display any ideas no code numbers showing it is a 3 compartment trailer.
31-03-2009, 06:15 AM #2
Re: thermo king tesco unit fault door code
Are you refering to the door alarm? That would be a magnetic switch on the rear or side door. It can be cured by replacing the switch, (sometimes, its hit and wires are damaged.), or we have also removed the fuse to prevent further issues. (Customers request.)
Hope this helps.
were are you exactly by the way?
01-04-2009, 07:14 PM #3
have u tried asking reefer john hes from telford
01-04-2009, 07:17 PM #4
thanks for that found the wiring but there is no switch on the door the wiring is in the trunking and somebody had not insulated them thanks for the advise about the fuse i am in the uk midlands area
03-04-2009, 04:01 PM #5
I seem them "ripped off" all the time.
Cheers!
mid-size refrigerated truck Thermo King unit question
By coldkeeper1 in forum TransportReplies: 11Last Post: 11-05-2008, 09:42 PM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Fault with Tango cassette
By airefresco in forum Air ConditioningReplies: 8Last Post: 19-09-2007, 08:42 AM
