Results 1 to 17 of 17
    Apr 2008
    West Yorkshire
    42
    Help using coolpack for cold room
    Hi I have a room being stored in a supermarket that is 3 x 2.5 x 2 and it will be storing meats. The ambient store temp is 20c. How can I utilise coolpack to make this calculation. I also would like to know what Tcool(h) means. Any help would be useful, this is for a college work and I just want to know if I using this program correctly. Thanks.
    11,025
    Re: Help using coolpack for cold room
    Have you tried the HELP files of Coolpack?
    Apr 2008
    West Yorkshire
    42
    They don't tell you anything. I may have to do this manually.
    Feb 2008
    Norway
    57
    446
    Tcool [h] means the time for the cool down of the warm products loaded into the cool room. "T" says it is time, "[h]" says the time is in hours.
    Apr 2008
    West Yorkshire
    42
    Quote Originally Posted by SteinarN View Post
    Ok, thanks.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by W.Miller View Post
    This is from Help:Printing _Description of model_.pdf
    I think that description is good enough for average person.
    Apr 2008
    West Yorkshire
    42
    Sorry to be a pain, but does that mean if I wanted to cool meat down to -18 from 15c would I change the Tcool to 1 hour. Is that normal industry standard.
    Split Croatia
    57
    6,151
    36
    Yes, that mean that, and not, that is not industry standard.
    For illustration purpose:
    http://www.meatupdate.csiro.au/data/Meat_93_24.pdf
    Feb 2008
    Norway
    57
    446
    I doubt 1 hour is industry standard.
    The actual cooling/freezing time is highly dependent of the air flow, the size of the meat pieces and whether it is packed or hanging free.
    If it is not a fast cooling/freezing room I would have set the Tcool to 24 hours and the set the quantity of products to load every day some 20 to 30 percent higher than the real quantity loaded into the room every day. Or alternatively set the real quantity and set a Tcool of 15 to 18 hours. This would give a reasonable spare capasity for defrosting.
    Apr 2008
    West Yorkshire
    42
    Ok after using cool pack I came up with these answers.
    (uncooked meat)
    Room size = 3 x 2.5 x 2
    Troom = 0c
    Rh = 85%
    Ambient = 23c
    Rh = 65%
    Acf = 9
    goods = 1000g
    Tin(c) = 17
    tcool = 15
    Persons = 1
    Work type = heavy
    Lights 100w/m2
    Now it says I need a maximum of 7.8 kw for the room stated.
    All I would like to know is 7.8kw enough for this space?
    Split Croatia
    57
    6,151
    36
    (uncooked meat)
    Troom = 0c
    Rh = 85%
    Ambient = 23c
    Rh = 65%
    Acf = 9
    goods = 1000g
    Tin(c) = 17
    tcool = 15
    Persons = 1
    Work type = heavy
    Lights 100w/m2
    For 1000g of goods in 15 hours, more than enough.
    Apr 2008
    West Yorkshire
    42
    Excellent I will add that calculation to my work and hopefully get a pass mark.
    Feb 2008
    Norway
    57
    446
    What did you get as an average capasity requirement?
    Apr 2008
    West Yorkshire
    42
    I think it was around 3.7 kw.
    Feb 2008
    Norway
    57
    446
    I would have used the average capasity requirement as this gives a reasonable spare capasity.
    The max capasity is the capasity needed to avoid the cool room temp increasing temporarily if the daily meat is put into the room all at once. This capasity requirement is also subjected to a number of aproximations in the coolpack program. A somewhat different number can be as correct as the coolpack number.
    Apr 2008
    West Yorkshire
    42
    The max capasity is the capasity needed to avoid the cool room temp increasing temporarily if the daily meat is put into the room at once. This capasity requirement is also subjected to a number of aproximations in the coolpack program. A somewhat different number can be as correct as the coolpack number.
    Thanks I will take your advice.
    Apr 2008
    West Yorkshire
    42
    When I think about it if I have to size and select refrigeration plant for this. So working of the maximum capacity is probably the best option. For example if I size it at 3.6 kw and the temp does rises unexpected, the system will not be able to cope with the extra demand. If you catch my drift.
  1. Maneurop MT51HK4A - Freezer Room
    By Hatchy in forum Trouble Shooting
    Last Post: 09-08-2010, 12:10 PM
  2. Blind Cold room specs help
    By frostedflake in forum Trouble Shooting
    Last Post: 13-03-2009, 01:49 AM
  3. Help with Condensation in Fitness Room
    By S_Line in forum Trouble Shooting
    Last Post: 04-03-2009, 12:52 AM
  4. Thawing Room (defrosting Room For Meat)
    By arunuae in forum Commercial
    Last Post: 09-02-2008, 09:24 AM
  5. Freezer Room Panels
    By Feeze in forum Technical Discussions
    Last Post: 22-04-2005, 05:58 AM
