Results 1 to 2 of 2
    benjturla's Avatar
    benjturla Guest
    Smile Chiller Efficiency
    Hi Guys,
    Please somebody help me on this, please help me to calculate the chiller efficieny based on ambient temp. for example the chiller is running at 75% with condenser water temp at 75oF Temp IN & 81.9oF Temp with a efficiency of 0.55 KW/Ton. If the chiller is running at 75% at 84oF Temp IN and 93oF Temp OUT what is the efficiency in KW/Ton?
    Jun 2005
    California
    394
    Re: Chiller Efficiency
    Quote Originally Posted by benjturla View Post
    Hi Guys,
    Assuming GPM is constant and runningat 75% at the higher condensing temp you have 0.55KW/ton at a 7 degree cond.temp . difference or 0.55/7 = ~8. So what if we say at a 9 degree difference(84oF Temp IN and 93oF Temp OUT) say 8 x 9*= ~ 7.1KW/ton Does that make sense for you or you could take phase kW= kV*amps*power factor*1.73
  1. process chiller help
    By talon771 in forum Industrial
    Last Post: 12-01-2011, 08:42 PM
  2. Dunham Bush Chiller Alarm
    By Regulator in forum Air Conditioning
    Last Post: 08-12-2010, 01:42 AM
  3. Absorption Chiller VS Mech. Chiller
    By Intern in forum Industrial
    Last Post: 30-05-2009, 08:31 AM
  4. york chiller motor rotation error
    By cesarnino in forum Trouble Shooting
    Last Post: 13-12-2008, 03:43 PM
  5. Trane CVHE 450 R11 Centrifugal Chiller
    By albertjoseph in forum Air Conditioning
    Last Post: 06-10-2008, 03:23 PM
