Thread: Chiller Efficiency
27-03-2009, 05:38 AM #1
Chiller Efficiency
Hi Guys,
Please somebody help me on this, please help me to calculate the chiller efficieny based on ambient temp. for example the chiller is running at 75% with condenser water temp at 75oF Temp IN & 81.9oF Temp with a efficiency of 0.55 KW/Ton. If the chiller is running at 75% at 84oF Temp IN and 93oF Temp OUT what is the efficiency in KW/Ton?
27-03-2009, 06:28 AM #2
Re: Chiller Efficiency
Assuming GPM is constant and runningat 75% at the higher condensing temp you have 0.55KW/ton at a 7 degree cond.temp . difference or 0.55/7 = ~8. So what if we say at a 9 degree difference(84oF Temp IN and 93oF Temp OUT) say 8 x 9*= ~ 7.1KW/ton Does that make sense for you or you could take phase kW= kV*amps*power factor*1.73
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
Absorption Chiller VS Mech. Chiller
By Intern in forum IndustrialReplies: 20Last Post: 30-05-2009, 08:31 AM -
york chiller motor rotation error
By cesarnino in forum Trouble ShootingReplies: 7Last Post: 13-12-2008, 03:43 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM
