Thread: 4-Way Valves
    shegs's Avatar
    shegs Guest
    4-Way Valves
    Hello All
    would anybody know for sure if all 4-way valves have the same orentitation in a de-energised condition, (looking at the valve from the coil side). The one I have is top centre port to the bottom right hand port and bottom centre port to the bottom left hand port. I was wondering if all valves are the same.
    Thanks for any help
    Mar 2009
    west l.a
    Re: 4-Way Valves
    You posted in the wrong section, you should try the a/c section,
    Good luck
    Oct 2007
    Britain
    220
    Re: 4-Way Valves
    http://www.refrigerationbasics.com/1...eat_pumps1.htm
    Hi Shegs,
    They are all the same, you will find a good explanation above.
    Tutto il Mondo e un Paese
  1. Installation of NRVS check valves
    By Josip in forum NH3
    Last Post: 02-12-2008, 01:33 PM
  2. Stainless steel valves
    By Tycho in forum NH3
    Last Post: 05-11-2008, 02:16 PM
  3. Understanding Balance port TX valves
    By Mobbsy in forum Technical Discussions
    Last Post: 23-07-2008, 04:32 AM
  4. Hinari and how far to open valves
    By stryker in forum Air Conditioning
    Last Post: 14-04-2008, 01:47 AM
  5. dan foss tx valves
    By fuzzy in forum Trouble Shooting
    Last Post: 02-10-2007, 01:11 PM
