Thread: Cooling load
25-03-2009, 06:23 AM #1
Cooling load
hello,
i design Ac system for a house, single family.
i have floor area, is that necessary for calculating the cooling load?
i find ashrae standard, is that right?
i am a student of ME, so if supply hints or name of book is enough, i will do the research my own.
Caleb
Hong Kong
25-03-2009, 06:45 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Cooling load
25-03-2009, 08:51 AM #3
Sorry...not HVAC software..wt i need is Cooling load & air flow free software
hello,
i am still searching info for my design project for AC systems
and is there any free software for cooling load and air flow?
is that air flow i need to calculate?
PS: i get the required place area(floor plan) only
caleb
25-03-2009, 10:19 PM #4
HVAC software i need is Cooling load & air flow free software
Hi Caleb :
Welcome to HVAC groupe. I bet the following webpage [HVAC-SOFT] is full of software gifts for students like you and many guys in the forum.
"It is a suite of simplified HVAC software has been developed by the instructor and students of the HVAC and Energy Conservation courses at The University of Alabama. It attempts to follow basic ASHRAE calculation procedures. The programs are provided at no cost to the public.
- New - Heat&CoolCost08.xls (43 kB download) - A program for estimating heating, cooling, and water heating cost.
- HVACPowDen08a.xls (2.4MB download) is a program for quickly estimating the required capacity and electrical demand of cooling and heating equipment for 30 different building types in the 10 US climate zones. Results are expressed in cooling tons, Btu/hr-ft2, total kW demand, and W/ft2. Program is now integrated with HVACSysEff.xls. Developed as part of an EPA-sponsored Energy Star Buildings project.
- HVACPowDenInstructions
- E-Ductulator08 (300kB download) is a program for designing air distribution systems and computing losses with the Equal Friction/Equivalent Length method. New equivalent length tables for rectangular and round duct fittings with friction options for metal duct, spiral duct, duct liners, duct board, and flex duct. Register, diffuser, and filter (for MERV = 4, 6, 8, 11, and 14) losses also included.
- E-PipeAlator08 (395kB download) is a program for designing water distribution systems and computing losses. Program handles water and water-glycol mixtures, (temperature corrected) in steel, cast iron, polyethylene, PVC and copper (a new feature) piping. Equivalent lengths for common fittings automatically entered. Heat exchanger, valve, and flow control valve losses also considered.New GSHP piping example calculations and figures have been added.
- PsychProcess08 (140 kB download) is a program for computing the properties (enthalpy, specific volume, humidity ratio, relative humidity, specific heat, and dew point). It also calculates resulting properties for air mixing, cooling, and heat recovery. Total, sensible, and latent capacities computed for cooling and heat recovery processes.
- ResLoad08 (486kB download) - A Residential Heating and Cooling Load Calculation program based on the 2001 ASHRAE Handbook of Fundamentals and HVAC Simplified (available from ASHRAE).
- TideLoad08B - Heating and Cooling Load Calculation Spreadsheet (1007 kB download) - Eight Zones with condensed CLTD/CLF/SCL tables. Includes traditional sensible load calculations plus new latent loads, heat recovery unit adjustments, and duct loss/gain options. New Worksheet for computing ASHRAE Standard 62.1-2004 ventilation air requirements. Excel Program is unlocked so user can add more zones and expand capabilities if adventuresome.
- Instructions for TideLoad (68 kB download)
- A-AHPCorrect08 is a program to correct the cooling performance of a model line of air-to-air heat pumps for various outdoor air temperatures, indoor temperatures, and indoor air flow rates. Performance correction of other product lines can also be used by entering nominal performance data in a “MfgData” worksheet.
- DuctCostCalc04 (61kB download) - A Spreadsheet to compute the cost of ductwork – Rectangular and Round Metal, Insulation, Duct Board, Flex Duct
- W-AHPCorrect04 (61kB download)- A Program to correct the performance of Water-to-Air heat pumps for various air and water temperature and flows.
- NetLoopCost (17 kB download) - A FREE Spreadsheet to compute the cost of installing and grouting vertical ground loops "
Read and share !
JoseiLast edited by josei; 25-03-2009 at 10:36 PM.
19-11-2009, 02:20 AM #5
Re: HVAC software i need is Cooling load & air flow free software
Thank you very much this helps a lot...
28-11-2009, 11:04 AM #6
Re: Cooling load
Gents,
Do you know some specialized software for HVAC calculation (heat load/losses, air flows, pressure loss, D&ID and etc.) in the offshore industry, ships?
Any advice is much appreciated.
rooibos
03-02-2010, 03:03 AM #7
Re: Cooling load
Thanks a lot Josei. You are the man.
Cooling Load Calculations
By hamidpia in forum Tools and CalculatorsReplies: 7Last Post: 05-02-2009, 08:57 PM -
Infiltration Cooling Load?
By Rankin755 in forum FundamentalsReplies: 4Last Post: 13-12-2008, 06:26 PM -
Heat transfer coefficient - Coolpack
By Graham in forum FundamentalsReplies: 10Last Post: 28-05-2008, 01:08 AM -
By jervame_sireh in forum FundamentalsReplies: 0Last Post: 21-04-2007, 11:05 PM
