Thread: Reach in Freezer Problem *Help*
25-03-2009, 01:44 AM #1
I got a coldtech reach in commercial stainless steel freezer. Its charged with 404a. compressor comes on fine. I touched the condenser and liquid line and its frigging colder then the evaporator!! wth is going on? Can someone guess what it could be?
25-03-2009, 02:18 AM #2
Re: Reach in Freezer Problem *Help*
Sounds interseting, check if system has hot gas defrost system incorporated, may be that controller has failed to continuous defrost, or possibly the reversing valve has jammed/failed in defrost position. First thing is fit a set of gauges to system and see whats going on. Both suction and high side gauges.
magoo
25-03-2009, 05:22 PM #3
23-08-2009, 03:15 PM #4
thanks guys, it was a blocked liquid line.
23-08-2009, 06:25 PM #5
1. What was in the liquid line/
2. Which product did you use to flush it out? ................meaning what worked for you, as there are so many/
Thanks..............
Island freezer problem
By Shamel in forum Supermarket RefrigerationReplies: 6Last Post: 06-10-2008, 08:06 PM -
whirlpool fridge freezer problem
By anubis68 in forum Trouble ShootingReplies: 0Last Post: 04-06-2008, 09:38 AM -
coolinf fan problem samsung rs21 dgrs fridge freezer
By bogtrotter in forum Trouble ShootingReplies: 6Last Post: 21-03-2008, 08:45 PM -
reach in freezer used as cooler
By Sledge in forum CommercialReplies: 5Last Post: 15-06-2007, 04:11 PM -
Problem with freezer fan.
By fridg in forum FundamentalsReplies: 15Last Post: 13-04-2006, 01:51 AM
