    Mar 2009
    united kingdom
    81
    fridge/freezer not cooling
    Hi can anyone help i have a phillips/whirlpool fridge freezer the frozen part door was left slightly ajar and the whole compartment iced up i switched the fridge of and let it defrost after a while i managed to get it started again but its not icing up anymore the compressors running but does,nt seem to nbe doin much any ideas?
    Dec 2008
    UAE
    42
    171
    Re: fridge/freezer not cooling
    Dear Check for the compressor running or if the compressor is running then check for fan as due to excess ice there may be some damage.
    If these are not the reason the reply me back
    thanks
    Jan 2009
    41
    [quote=wilt;139358]Hi can anyone help i have a phillips/whirlpool fridge freezer the frozen part door was left slightly ajar and the whole compartment iced up i switched the fridge of and let it defrost after a while i managed to get it started again but its not icing up anymore the compressors running but does,nt seem to nbe doin much any ideas?[/quote
    Hi, is your machine frost free??? if so how long did you defrost it for?? i would recomend two days with the door open. This is because if it is frost free it works on an air flow and if there is ice still in the system it stops the air flow.
    Mar 2009
    united kingdom
    81
    my fridge has no fans & its completly defrosted the condensor coil is on the back outside wall and is of convection type when the comp is running i can hear liquid or gas flowing im wondering if its not going to full speed ie run windings or circuit?
    Dec 2008
    UAE
    42
    171
    Dear Wilt,
    Because of the excess frosting on the eva., the load on ref is increase hence there is a possiblity of High pressure joint leak. Check for leakage as it will lead to no cooling.
    thanks
    amit
    Mar 2009
    united kingdom
    81
    thanx amit i will fit some gauges and check pressures problem being theres only 0.80 grammes R 12 in system
  1. Energy saving Glycol filled dry cooler circuits
    By Jasper in forum Technical Discussions
    Last Post: 19-06-2008, 02:18 PM
  2. Compressor loading, cooling, and range of operation.
  3. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
  5. upside down fridge/freezer not cooling properly
    By Barney01 in forum Domestic
    Last Post: 07-10-2005, 08:20 AM
