Results 1 to 2 of 2
23-03-2009, 04:40 PM #1
Bosch fridge freezer - fridge strange behaviour
Hi - any help appreciated
I have a Bosch Lgoxx fridge freezer, KGU32121GB. A few weeks ago I started to notice ice forming on the floor of the freezer section. Which I assume is because some drainage channel has become blocked. I've tried to unblock this by turning off the unit, in case it's blocked by ice. This didn't work and so I'm arranging for my neighbour to look after my frozen food so I can try again.
In the meantime I now have a problem with the fridge section. Although the freezer still keeps to its set temperature, the fridge started to warm up. If the fridge is set to 6 degrees then it keeps to that temp. But if the temp is set to 4 degrees, then it warms up to room temp. I don't understand why it acts differently when the temp is set at 4 or 6 degrees.
Any ideas anyone? And will my defrosting the unit solve the fridge's erratic behaviour?
Thanks in advance.
Geoff
24-03-2009, 07:47 PM #2
Re: Bosch fridge freezer - fridge strange behaviour
Hi, first i would defrost the drain hole with a steamer (i use an ordanary wall paper steamer)
With regarads the fridge problem i would stab a guess at pcp / sensor
BOSCH Fridge/Freezer - fridge wont cool....freezer fine
By andy_lanc in forum DomesticReplies: 6Last Post: 25-10-2010, 01:25 PM -
Bosch Fridge Freezer Error Code ??
By madfriday in forum DomesticReplies: 3Last Post: 29-04-2010, 09:01 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
bosch fridge freezer
By geoffishere in forum DomesticReplies: 16Last Post: 05-08-2008, 05:13 PM
