Results 1 to 11 of 11
    India
    688
    Expansions joints in cold store flooring
    Does any one has any specific details on this aspect. We find that if the expansions joints are very near to the door opening, due to movement of Fork trucks the chances of floor getting damaged are more. There must be a definite solution to this issue
    Oct 2003
    5,630
    34
    Re: Expansions joints in cold store flooring
    Why you need expansion joints anyhow, besides those on the walls?
    India
    688
    IN the RCC flooring done on top of the Conventional Flooring insulation this is always done. But our experience shows that the Civil guys are not aware on this issue
    Oct 2003
    5,630
    34
    What's the RCC flooring?
    Mar 2009
    1
    Exclamation This is a great article
    This is a great article. I’m new to blogging but still learning. Thanks for the great resource.
    Sep 2006
    Venezuela
    259
    hello smpsmp45
    The floor in a cold store is a very interesting isue
    The Expansions joints are very import in big Cold Warehouse.
    We make it in two way:a) WE make a cilinder and piston type union .The steel bar in the concrete ,just in the joints , are conected with a special union that look like a piston and cilinder .We put some grease to garantee movements. Note the movement is only horinzontal. b) there are another way using a joints with a metal in triangular form. You instal one in a direccion an another in the other way. This type of joint has a two direction movements .Horizontal and vertical.
    the floor is cut in the joints place with a saw more or les 3 mm.The groove is filles with a especial resin
    Sep 2006
    Venezuela
    259
    Gossioii1
    I couldīt see the article Could you please post it again?
    Gwapa
    India
    688
    Yes I am also keen to get that article.
    Dear Gwapa
    Our experience is that the grooves must be atleast 2.5 mt away from the door. That is to take care of load of the MHE( Fork Truck!!!)
    But I am looking for some special info on this. Your Cylinder piston concept is really good. Can you send more details on that?
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, Petert_1
    It can be acronym for many things... see this...
    http://acronyms.thefreedictionary.co...ncreteeviation for many things like here
    In Vietnam when we build a concrete factory for dam RCC meaning was - Roller Compacted Concrete ... the way of dam building/construction
    but here can be also Reinforced Cement Concrete ...
    Best regards, Josip
    Sep 2006
    Venezuela
    259
    smpsmp45
    May be this link could help you
    Gwapa
    http://www.performanceflooring.basf-...reparation.pdf
    India
    688
    Dear Gwapa,
    It is very informative article, Many thanks
  1. Fruit cold store design
    By Josip in forum Technical Speculations
    Last Post: 12-09-2008, 11:29 AM
  2. Cold Store Panel
    By snow_man in forum Trouble Shooting
    Last Post: 31-07-2008, 08:05 AM
  3. Slope if the cold store flooring
    By smpsmp45 in forum NH3
    Last Post: 03-07-2008, 08:59 AM
  4. cold store flooring preparation
    Last Post: 18-05-2008, 03:45 AM
  5. Expansion Joints in the cold store floor
    Last Post: 17-05-2008, 07:47 AM
