Thread: Freezer Flatlining
20-03-2009, 11:44 PM #1
Freezer Flatlining
I got a ColdTech/Minus Forty upright single door freezer which is giving me some problem.
What i mean by flatlining is that it never reaches its designed temperature which is set by thermostat.
Set point is set for -20 F But it only reaches to about -9 and keeps cycling.
Its charged with 404
Temperature probe is properly installed
Control was replaced with new digital one but no luck.
What could it possibly be?
21-03-2009, 03:36 AM #2
Re: Freezer Flatlining
is r404 on the cascade side of it. just thats a bit cold for r404. need mo info ie. is there a subcooler ? wat is the second stage doing ? (if it has 1 )pressures stuff like that
21-03-2009, 11:57 AM #3
This is not a cascade system.. Its a upright single glass door merchandiser.
Its a closed system.
21-03-2009, 12:17 PM #4
You say:
if not the thermostat, is it cycling on an LP control?
21-03-2009, 01:21 PM #5
This unit has a digital controller that can be adjusted. I changed the controller and still same thing.
I finally solved the mystery and it was low refrigerant that was causing it to have low SC and High SH
21-03-2009, 05:03 PM #6
sultan
not much of a mystery after all . if it was just short of gas .Last edited by tony--1; 21-03-2009 at 06:41 PM.
22-03-2009, 12:19 AM #7
So where was the leak?
I trust you found and fixed it?
ice cream truck freezer
By GaryC in forum TransportReplies: 7Last Post: 06-12-2008, 02:19 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Freezer compressor running 20 Hours/day
By rickcw in forum DomesticReplies: 12Last Post: 08-03-2008, 11:50 PM -
Need help quick with walk-in freezer issues!
By hysiderafter in forum CommercialReplies: 5Last Post: 12-12-2007, 12:57 AM -
Trolley freezer & blast freezer
By smpsmp45 in forum NH3Replies: 0Last Post: 25-08-2007, 07:29 AM
