Results 1 to 8 of 8
    Apr 2005
    43
    14
    Grasso Single Screw Compressor
    Hi Guys
    I found this picture on my PC and thought I would share it with you all.
    This is a bit of refrigeration history I guess.
    Grasso used to make a single screw compressor mainly for marine applications before J & E Hall refined the technology further.
    The Compressor would be returned to the Grasso factory in Hertogenbosch for overhaul after exceeding the recommended run hours on a service exchange basis.
    Still do toady as far as I know?
    Hope you enjoy.
    Sturt.
    Dec 2005
    Norfolk, England
    132
    13
    Re: Grasso Single Screw Compressor
    Hi Sturt,
    The one in your picture looks like the one RM-Support has for sale. Have a look at my avatar and you will see a MS 1030 used on the high side of the plant that I had stripped out for gland service. Built in 1974 and still running with some MS1034 units as low side boosters.
    all the best Arthur
    Apr 2005
    43
    14
    Hi Arthur
    Great stuff thanks for replying.
    I dont have any information on the construction of these. Do they have a single star wheel?
    It looks as if the whole compressor body needs to be split for major works?
    Thanks again.
    Sturt.
    Dec 2005
    Norfolk, England
    132
    13
    hi Sturt,
    They have two star wheels the same as the Halls unit, Grasso stopped overhaul/servicing them some time in 1986-87. We have split two old dead units after the rear main bearing on the rotor shaft had worn letting the rotor move backwards. But you could not get the bearing from SKF as Grasso owned it's rights. Can still get some parts for them from Grasso. A lot of the Grenco engineers have not seen one or worked on them.
    Arthur
    erny's Avatar
    erny Guest
    Hi all MonoScrew Enthousiasts!
    The base idea is very old, around 1500 Leonardo da Vinci used already this principle (globoide worm mechanisme). The Frenchman Zimmern was the inventor of an air compresser according this principle and Grasso got the rights (in 1971) after 4 years development they succeeded to transform it into a refrigeration compressor. It was patented, also the name MonoScrew. Main (driven rotor) was made of aluminium and the 2 side wheels were cast iron. Because of it's symmetry it was almost vibration free! The precious production of the wheels became a problem with the machinery in those days. The best was to start and than never stop, than they could run ages ! (breweries etc)
    If interested I can scan the origanal introduction brochure.
    I'm refr. eng at GEA Grenco (a daughter company of Grasso) and I worked with the MonoScrew
    Nowadays Daikin makes them too (very small onesin AC units) also Filter and Hall.
    Ernst
    Apr 2005
    43
    14
    Hi Ernst
    Thanks for the information.
    I've heard the Zimmern name before in relation to these compressor types.
    I would be interested to see the original brochure and then I think we have great history thread for sure.
    Sturt.
    riknik's Avatar
    riknik Guest
    we have a client that has 2 of these still running, (had3) over 20 years old and have never had a spanner near them, noisey old thing but serviced there perpuse i guess
    Dec 2005
    Norfolk, England
    132
    13
    Hi all, Had a sad day at the start of this year when I shut down and pumped out for the last time all of the Ammonia from our old system powered by the mono screws. But on a better note we are now running on two new SP two stage duo packs at around 1.25 maga watt,s.
    arthur
  1. Single screw compressor
    By dvtruc in forum Industrial Compressors
    Last Post: 28-01-2010, 03:40 PM
  2. Oil Lifting Problem in NH3 screw compressor
    By SURESH YADAV in forum Refrigeration - The Stories
    Last Post: 16-10-2009, 01:34 AM
  3. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  4. Stal Screw Compressor R5-mkii 100kw
    By REFSOO in forum Trouble Shooting
    Last Post: 20-01-2007, 01:09 AM
  5. screw compressor failure
    By aygul in forum Trouble Shooting
    Last Post: 09-12-2004, 09:09 AM
