Thread: Relief valve piping
19-03-2009, 03:54 AM #1
Relief valve piping
Does relief valve piping for ammonia have to be A106
19-03-2009, 04:34 AM #2
24-03-2009, 01:03 AM #3
Re: Relief valve piping
In NZ we use screwed galvanized seemed pipe, and the M&M sets I seen overseas, they are similar. But still check your local standards authourity to clarify
magoo
27-03-2009, 08:08 PM #4
ASHRAE and thus US aligned standards require discharge piping from safeties to be of same material as "that required for the refrigerant". ASHRAE -15, 2007, 9.1.5.
The sizing of common discharge pipes has gotten much more involved: per 9.7.8.5, and Appendix H, same source. Not uncommon for the Machine Room header pipe to be 5" and larger for a large scale system.
The BSR has very much the same content though I cannot give you the section references etc.
23-07-2009, 03:08 AM #5
Thanks for the reply,sorry took so long computer crashed and had to get new one,thanks again
Relief Valve Exit Piping
By nh3wizard in forum Technical DiscussionsReplies: 0Last Post: 17-12-2008, 04:49 PM -
Oversize Relief Valve
By Dacosta in forum NH3Replies: 1Last Post: 05-09-2008, 11:35 AM -
Piping relief valves to atmosphere
By Superheatman in forum IndustrialReplies: 0Last Post: 26-09-2007, 07:30 PM -
Carbo Cooler relief valve
By flasah in forum NH3Replies: 2Last Post: 24-06-2006, 09:31 AM -
Relief Valve on Suction
By Latte in forum CommercialReplies: 19Last Post: 20-01-2004, 11:57 PM
