Thread: Empty tank weight?
18-03-2009, 06:04 AM #1
Empty tank weight?
I've got a partial tank of dupont 410a how much does an empty tank weigh? so i can figure out how much is in it, i'm sure this is a very easy question but i can't find the answer by searching.
thanks everyone.
18-03-2009, 06:52 AM #2
Re: Empty tank weight?
I've got a piece of string which has had a bit cut of the end, can anyone tell me how long it is now?
Easy question? or perhaps you need more information as there are so many different lengths of string from different manufacturers.
18-03-2009, 09:18 AM #3
If it's a conventional refrigerant cylinder (as opposed to something you've picked up on your travels) it will have the Tare weight stamped on the cylinder identity plate.
The rest is arithmetic.
But, beware of refrigerant that you don't know the pedigree of - it may be contaminated.
Need Help on Design/sizing of Mixing Tank - Industrial Cooling
By oren in forum IndustrialReplies: 2Last Post: 08-12-2008, 09:34 PM -
By oren in forum Technical DiscussionsReplies: 0Last Post: 08-12-2008, 02:20 PM -
Recovery tank
By dddon in forum Chit Chat & Service StoriesReplies: 5Last Post: 01-12-2008, 02:53 AM -
Calculation bypass buffer tank volume
By abbasi in forum New TechnologiesReplies: 3Last Post: 16-10-2008, 06:19 AM -
How an expansion tank works?
By Raadster in forum FundamentalsReplies: 6Last Post: 25-07-2008, 02:25 PM
