Thread: Refigerator Climate Type
16-03-2009, 02:27 AM #1
I have seen climate type SN, N, ST and T in refrigerators. Can anyone give me a reference to find out what they are?
I believe that they relate to ambient operating conditions and understand (have been told) that they relate to SN = 25C; N = 32C; ST 38C and T 43C. Are these numbers correct?
16-03-2009, 08:09 AM #2
Re: Refigerator Climate Type
Yes, You are right, these are climate class, you can find these details in EN 153 Standard. If you dont have then reply. I will send you the same.
16-03-2009, 08:11 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,175
- 6
- 36
Not exactly:
Climate class of fridge freezers
Every fridge freezer has a 'climate class', which tells you the range of room temperatures with which it can cope. The two you're most likely to come across in the UK are N class and SN class. Both work effectively in room temperatures up to 32°C.
N models shouldn't be used in rooms that become colder than 16°C. SN models shouldn't be used at room temperatures below 10°C.
Other classes that you might come across are ST and T. ST models work best at between 18°C and 38°C, and T models between 18°C and 43°C.Last edited by nike123; 16-03-2009 at 08:14 AM.
17-03-2009, 02:01 AM #4
If you could that would be much appreciated.
nike123 thanks for that
The question relates to a caravan I just bought and am using in Australia. Sydney (where I live) HVAC design is 32CDB. Tropical North Queensland could be 40's. My fridge is an SN and stopped working (everything defrosted) when ambient went to low 30's.
Trying to work out if I have a case of wrong climate class against the manufacturer of the van to get fridge changed.Last edited by Futsal1st; 17-03-2009 at 02:04 AM. Reason: extra info added
09-08-2010, 01:24 PM #5
can you send me a copy as well??
breaker type?
By tait71 in forum ElectricalReplies: 24Last Post: 05-09-2010, 04:39 AM -
How do you determine type of refrigerant in the system?
By tomtom in forum RefrigerantsReplies: 11Last Post: 12-02-2009, 10:06 AM -
410A guages which type?
By N.Lewis in forum Tools and CalculatorsReplies: 6Last Post: 01-09-2008, 05:27 PM -
earth leakage
By sid in forum ElectricalReplies: 33Last Post: 11-07-2008, 07:58 PM -
New or Old type of Chiller
By sagittarius in forum CommercialReplies: 4Last Post: 16-03-2008, 03:10 PM
