    nambkdn's Avatar
    nambkdn Guest
    Please help...Document about Heatpipe
    I need some document about heatpipe, special about thermosyphons.
    Please help me! Thanks
    11,025
    Re: Please help...Document about Heatpipe
    Split Croatia
    6,151
    nambkdn's Avatar
    nambkdn Guest
    Thanks for your post!
    Mar 2009
    KZN, South Africa
    64
    2,212
    Most good university, or college heat-transfer textbooks will have a section on the basics of heat-pipes.
    If you use e-mule, you should be able to locate a few good books on heat-pipe operation & design.
    Jun 2008
    Hong Kong
    35
    Hi there,
    How to make a heat pipe? What is the material inside?
    Thanks in advance.
    Petko Stoyanov's Avatar
    Petko Stoyanov Guest
    The easiest way is with water ... fill half the pipe with water and evacuate ... boiling starts in 30 degrees celsius
    Aug 2007
    Sydney
    1,083
    This device in its advanced form is used for the relativly new solar hot water heat tubes made of cu and lo iron glass. And I think I saw some superconducting heat pipes on a net search too.
  1. Please help me. Finding NISTIR 89-4104 document
    By Yuri Han in forum Tools and Calculators
    Last Post: 21-09-2007, 10:50 PM
