12-03-2009, 07:09 AM #1
Thermo King SBIII Alarm Code 17 Help!!!
Hi everyone,
I have Thermo king SBIII and it was running fine when I turned it off after I picked up the load and try to start it and it won't start. Giving me Alarm Code 17 at this time I can't even find any Technision so any help would be greatly appreciated.
12-03-2009, 07:20 AM #2
Re: Thermo King SBIII Alarm Code 17 Help!!!
Code 17 is engine failed to crank.
Does does the starter run at all? If not, is power present at the wire to the starter solenoid when the starter should be cranking?
If power is present but the starter does not run, then your starter or starter solenoid is probably faulty.
12-03-2009, 07:40 AM #3
12-03-2009, 07:46 AM #4
Is there any way to fix this problem on my own right now? because by tomorrow my load will go bad.
12-03-2009, 05:50 PM #5
Do you have enough power in the battery? What is the battery voltage before the starter tries to engage?
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 23-01-2012, 11:23 PM -
Thermo King Alarm Code
By sneaquie in forum TransportReplies: 7Last Post: 21-01-2011, 06:27 AM -
Thermo King SBIII Alarm Code 29???
By ppodsiadlo in forum TransportReplies: 1Last Post: 31-12-2008, 10:04 PM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 08:01 AM
