    Sep 2008
    ROMANIA
    45
    5
    air conditioning for bakery
    Hi, could someone tell me about cooling systems used for cooling bread (bakery products). I have a situation , in a bakery factory, the bread enter in the room with about 90 degrees and in about 3 hours must be cool down to 28 degrees. The quantity is about 600 kg. The room volume is about 60 mc. It result about 25 kw at the T0=+15 and Tk= +45
    I know that are problems with cooled air throw directly on the product.
    Could anyone give some publications , articles about the cooling technology in bakery industry ??
    Jul 2008
    London
    848
    Re: air conditioning for bakery
    Quote Originally Posted by viorelbuiuc View Post
    Use a sock system and high grade filtration (clean regularly!)
    Mar 2006
    Merate (LC) - Italy
    2,549
    Baked goods have a high latent heat of vaporization due to steam. At the same time, if cooling is too fast, bread and pastry can become moist and soft, instead than crispy.
    Therefore it is paramount that A/C is primarily sized on dehumidification rate, and a sensible heat factor of .3 to .5 to total heat.
    Split Croatia
    57
    6,151
    36
    Vacuum cooling
    Baking products for instance can be cooled down
    to ambient temperature in just three minutes after baking. This procedure
    allows a much longer shelf life for baking goods on a purely physical basis.
    Moreover, the resulting products are much healthier since the use of chemical
    additives can be reduced drastically or even eliminated. Spirig Engineering
    will continue to develop solutions for third parties.
    http://www.reuters.com/article/press...08+PRN20080228
  1. Replies: 11
    Last Post: 13-08-2008, 01:22 PM
  2. Unique cooling system Port-A-Cool replaces air conditioning
    By LC-Europe in forum New Technologies
    Last Post: 30-01-2008, 08:29 AM
  3. question on delta T values in air conditioning work
    By beachfronttech in forum Air Conditioning
    Last Post: 18-01-2008, 10:06 PM
  4. Replies: 2
    Last Post: 01-07-2007, 04:30 PM
