Results 1 to 21 of 21
Thread: inside split a/c systems
05-05-2004, 01:23 AM #1
can someone tell me where i can find information of exactly what is inside and split a/c unit (mainly the outdoor unit) in terms of refrigeration components; pipes, valves etc. (not really electrical components).
im particularly interested in daikin. do they have a technical website or something?
thanks,
paul
05-05-2004, 06:24 AM #2
Re: inside split a/c systems
- COMPRESSOR
- CONDENSER
- EXPANSION DEVICE
- ACCUMULATOR (possibly)
- ELECTRONIC CONTROL BOARD
All A/C condensing units contain these components, Heat pumps Also have a reversing valve,
05-05-2004, 07:43 AM #3
would my daikin split use a capillary tube or txv? where would it be? inside the indoor unit or the outdoor unit??
cheers
Paul
05-05-2004, 09:21 AM #4
Try www.daikin.org.uk/internet/uk/home.nsf
Should be plenty of info on here
Raymond
05-05-2004, 02:01 PM #5
hi paul,
it would also cotain, leaves from the closest tree, dead lizards, pieces of stikcs that kids push into the fan.
the expention device - cap tube will be betwen the bottom of the condenser and the liquid line valve.
cap tube used to be in the indoor unit but it makes high noise when when the refrigerant starts flowing or when there is refrigarnt shortage.
from that reason, it was moved into the outdoor unit.
chemi
05-05-2004, 08:09 PM #6
What - No FAN jasper???
06-05-2004, 02:28 AM #7
thanks chemi :-)
06-05-2004, 04:37 AM #8
I think he said NOT ELECTRICS franf
06-05-2004, 07:48 PM #9
06-05-2004, 07:54 PM #10
just shoot him frank
chemi
06-05-2004, 08:00 PM #11
Paul
Try this link - it's to a page on the Spaceair members site and it shows the technical liturature (sp?) for a Skyair system. If you scroll down you will find the schematic for the outdoor unit. Hope the link works as I'm a member but I can't give out my password - if I did I'd have to SHOOT you (as Chemi say's) http://www.spaceair.co.uk/cgi-bin/pa...121%20tech.pdf
Be patient it takes a while to load and is in pdf format
07-05-2004, 06:12 AM #12
DOH
07-05-2004, 08:18 AM #13
thanks frank,
thats the kind of diagram i am looking for. only for a mini split though. i guess its prob about the same
one question below....
cheers paul
07-05-2004, 06:05 PM #14
distributor -as a guess
cheers
richard
07-05-2004, 06:27 PM #15
hi slothslag,
indeed its a distributor!!
chemi
07-05-2004, 08:05 PM #16
10 out of ten boys - it is a distributor.
Paul - this is the small device on the end of the liquid line where it splits in to many small pipes to distribute the refrigerant equally into the evaporator. Give me the model number of the split and I'll see if I can post a link for you.
08-05-2004, 06:44 AM #17
Fire Sprinkler mounted upside down?
Distributor? Only one injection soldered of the distributor?
Rest is open? Wouldn't the gas not blow out the others?
08-05-2004, 01:55 PM #18
symbol for venturi, indicates a multifed coil is used.
"Old fridgies never die, they just run out of gas!"
08-05-2004, 01:58 PM #19
aka, distributor...
however upon further inspection i too along with peter am abit worried about where the gas is going..."Old fridgies never die, they just run out of gas!"
10-05-2004, 05:26 AM #20
Hi Frank,
on the outdoor unit it says its a Daikin RXD71JVEA
remember I live in australia so i dont know if that means different model numbers,
if you could direct me th where i could get a piping diagram; that would be great
cheers paul
31-10-2004, 12:24 PM #21
Paul unit is a 3hp r22 inverter,reverse cycle.
Layout of system as follows (On cooling from suction line).
Stop valve.
Reversing valve.
Accumulator.
Compressor.
Muffler.
Reversing valve.
Header.
Outdoor coil.
4 small capillary tubes in parallel
Distributor.
Muffler.
Motor operated valve.
FIlter.
Stop valve.
Regards.
Pressure testing for leaks on split a/c systems
By mrchatts in forum Air ConditioningReplies: 46Last Post: 08-04-2010, 10:02 AM -
My local Apprentice Training Classes
By shogun7 in forum TrainingReplies: 12Last Post: 17-03-2007, 03:10 PM -
HFCs for flooded systems?
By garyb in forum RefrigerantsReplies: 15Last Post: 21-04-2006, 10:02 PM -
Diy Systems
By kewlman in forum Air ConditioningReplies: 7Last Post: 22-07-2005, 01:08 AM -
Heater/cooler split system A/C electrical connections help pls!
By JamesQB in forum Air ConditioningReplies: 5Last Post: 22-06-2005, 07:41 PM
