Results 1 to 8 of 8
    Oct 2003
    5,630
    34
    Frick TDSH 355 l or PDSH 355L
    Hello,
    Someone is asking me for a Frick PDSH 355L but he nor I can't find any information about a PDSH.
    Therefore it could be that it is a TDSH.
    Does someone know a reliable rebuilder or wholesaler who could hold this machine propably on stock (new or rebuild)?
    Peter
    Somerset
    69
    4,700
    47
    Re: Frick TDSH 355 l or PDSH 355L
    Hello,
    Peter
    Hi peter.
    Sorry I can't be more helpful but the following details are listed as the nearest "Frick" dealers.
    It would appear that their new masters only list U.K.
    And no-one else in Europe.
    May be worth a try if none of the other guys respond.
    Bit I do know that here are a few on the forum!
    Cheers Grizzly
    Johnson Controls Limited, York Navy Systems
    2-3 Russel Square
    Hornsby Way
    Basildon, Essex SS TA England, United Kingdom Phone: 44 (0) 1268 246165
    Fax: 44 (0) 1268 246158
    E-Mail: Steve.T.Hayward@jci.com
    The above are listed as Marine.
    Frick's are generally Marine in the U.K. at least and land based is generally Sabroe. Not that there is much difference that I know of?
    As far as I am aware they are the same just badged differently.
    So it may be worth talking to your local Sabroe Guys?
    By the way it is TDSH. There is no PDSH.
    Jul 2007
    Czech
    61
    374
    Hi Peter, this question has already been to the Frick TDSH 233 of this forum
    Oct 2003
    5,630
    34
    Grizzly, thanks already for your help
    Peter
    The Netherlands
    54
    30
    Hello Peter,
    PDSH355 does exist, it is a special version of the TDSH model often used in natural gas/propane production on off shore rigs.
    Maybe I'm able to help you further on this one.
    Sep 2008
    Belguim
    64
    Hallo,
    Peter heeft zo vriendelijk geweest om mijn vraag te lanceren op de forum.
    U reageerde dat U misschien kon helpen.
    Ik ben op zoek naar zo'n compressor.
    Nieuw of remplasse is beiden OK.
    Welke gegevens hebt U nog nodig om mij verder te helpen?
    The Netherlands
    54
    30
    Hallo Koelgoeroe,
    ik zal mijn contact gegevens wel via je mailadres doorsturen.
    groet
    The Screwdoctor
    Sep 2008
    Belguim
    64
    Hi, Screwdoctor and Peter_1,
    Thank you very much to help me out so quick!
    It would be wonderful to receive the technical data of this type compressor as now I'm sure they exist.
    Koel goeroe
  1. Frick RWB II 270
    By willlie in forum Industrial Compressors
    Last Post: 13-12-2011, 04:00 PM
  2. Frick TDSH 233L
    By J.D in forum Industrial Compressors
    Last Post: 29-07-2009, 08:04 AM
  3. Frick compressor RXF 101-H
    By PaulZ in forum Industrial Compressors
    Last Post: 19-02-2009, 02:29 AM
  4. FRICK TDSH 233 Slide Valve and guide damaged
    By 404cab in forum Industrial Compressors
    Last Post: 30-07-2008, 11:24 PM
  5. Replies: 12
    Last Post: 16-06-2008, 10:06 AM
