    Mar 2009
    Belfast
    5
    moving air con unit
    can i pump system down move too new location use same gas in outdoor unit thanks
    Jul 2006
    Romania
    44
    99
    Re: moving air con unit
    yes you can do it!
    Don't foreget to vacuum it before you restart'it!!!!!!!!!
    Mar 2009
    Belfast
    5
    can i pump a air con system down move re instal use same gas in outdoor unit thanks
    Mar 2009
    Belfast
    5
    Quote Originally Posted by tarcau mihai View Post
    yes you can do it!
    do i close the liquid line and run it on cooling
    Mar 2009
    Belfast
    5
    thanks for that
    11,025
    Might be safer to get a AC technician in as it sounds like you could be getting into areas such as breaking the law regarding refrigerant handling.
    Jan 2009
    United Kingdom
    242
    Quote Originally Posted by Mark-Cool-IT View Post
    Yes, this can be done but there are a number of issues I would look at first if I was you 1. Is the unit capable of cooling/heating the area you are locating it to. 2. Would it be installed within maximum allowable length of pipe and height difference for this system. 3. Would you know the additional refrigerant required if extending pipework. 4. Have you got the correct materials/tools and experience to do the job. If your not an a/c engineer then my advice to you would be to get more advice from someone locally in the business. You would probably receive free site survey (this should answer these questions) and quotation.
  1. Replies: 12
  2. Vrv
    By tgoonter in forum Air Conditioning
    Last Post: 11-01-2011, 06:25 AM
  3. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  4. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  5. TK basic micro-p features and functions
    Last Post: 05-12-2007, 06:25 PM
