Results 1 to 13 of 13
Thread: R507a
    Mar 2007
    Iraq
    57
    Smile R507a
    Hi to every one
    I will be so thankful for explaining why R507a less used than R404a ?
    Jan 2006
    Valrico, Florida
    509
    Re: R507a
    Here
    Maybe this can help you
    Mar 2007
    Iraq
    57
    Re: R507a
    Dear nh3wizard
    Thank you but need the advantages and the disadvantages that made R404a preferable.
    Last edited by afak; 06-03-2009 at 07:02 PM. Reason: Reason: Changed my simple mind
    Nov 2006
    708
    23
    Re: R507a
    What application are you refering to ?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: R507a
    For no good reason, else than habit. I advice all of my customer for R507 instead than R404a
    Nov 2005
    belgium
    61
    Re: R507a
    R507 has no so much problems with the condensingpressure in winter than R404A. you can mix both without problems.
    R507 is manufactured by another company than R404A, R404A gets more publiciti, thas all
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: R507a
    Yes R507 is morphable with R404a, and in fact it's made up by the same constituents except R134a
    Jan 2006
    Valrico, Florida
    509
    Re: R507a
    Quote Originally Posted by afak View Post
    Dear nh3wizard
    Neither google nor googling are precise answers.The veteran members answer precisely and deeply that what made this forum highly respected between others there members run for only for higher number for answers and gaining so called (Rep power 4,5,10,500 !!!!!!) though there answers are shallow .We need new evaluation depend on quality of answers not quantity!!!!
    Should we go to google every thing and not come to the forum again?
    Thats all right AFAK', we wont have to worry about it much longer, must be nice to have what you are enjoying now at someone elses expense.
    Mar 2009
    ireland
    87
    Re: R507a
    remember the betamax (i think)verses the vhs ? its all about branding ...r404a won out ... but i would say r507 is a better gas
    Mar 2007
    Iraq
    57
    Re: R507a
    I am working on a design and insallation of blast freezer and think that R507 may give more cooling capacity and depth for the same compressors used for both R404 & R507 but need answer to see the effect on the designed capacity of other parts.And need any notice about advantage and disadvantage concern this refrigerant that made R404a more used preferable .
    Feb 2008
    adelaide sth.oz
    1,015
    Re: R507a
    probably a bit late for this post but 507 i have found to better in high ambients & more efficient overall.invented by a south aussie from loxton i believe.havent used 404 since working for myself the last 7 years
    Bailiff's Avatar
    Bailiff Guest
    Re: R507a
    R-507 does not exibit glide where R-404A does. This will result in R-507 to be about 1.5% more efficient. Though not significant, problems with maintaining tight temperature tolerance can be an issue with any level of glide. Pricing may also be an issue depending on where you are located.
    Jun 2007
    South Africa
    66
    120
    Re: R507a
    R-507's performance were better than R-404A, when doing a tuna boat. We went down to -70 C suction with R-507 on DWM Copeland 2-Stage Compressors.
    Had to change to low temp. oil that can operate up to -107 C.
    For some reason R-404A got stuck at -53 C Suction.
  1. Best refrigerator..R404a or R507a
    By AndrOvr in forum Refrigerants
    Last Post: 02-12-2010, 10:44 AM
