Results 1 to 2 of 2
    topfridgeman's Avatar
    topfridgeman Guest
    Condensate drainage regulations
    Consultants for a client I know are insisting that AC condensate drainage water is treated as foul waste. I'm told this is a regulation due to the possibility of Legionaires bacteria being present in the condensate water. Does anyone know which regulation is being cited here? The knock-on effect is the popular method of taking condensate, be it gravity or pumped, to outside where it can soak away or to a rwp is/will no longer be allowed by law!
    11,025
    Re: Condensate drainage regulations
    I would suggest that your client gets his consultant to provide the documentation to back up this claim.
    As all condensate from an ac unit should be below the +20°C bug limit I don't really see a problem.
    Mind you I could be completely wrong and will be shot down in flames shortly
  1. Where to use condensate pumps?
    By NexusR in forum Air Conditioning
    Last Post: 28-10-2008, 12:10 PM
  2. F Gas regulations - New qulaifications regulations published.
    By Argus in forum Legal-Business-Marketing
    Last Post: 20-06-2008, 08:24 PM
  3. New Regulations on F Gas
    Last Post: 17-01-2008, 07:55 PM
  4. Hartell Condensate Pump
    By Grizzly in forum Air Conditioning
    Last Post: 03-01-2008, 09:08 AM
  5. Cooling condenser of split with condensate from evaporator
    By smileypete in forum Air Conditioning
    Last Post: 10-07-2005, 08:21 AM
