03-03-2009, 04:40 PM #1
Correct Evaporator TD Calculation
Hello everyone. In commercial refrigeration (walk-in freezers/coolers), we typically estimate the evaporator TD by dividing condensing unit capacity by evaporator capacity (x10)...
But I would like to know the most accurate way to calculate this TD. Or if not calculation, must I find the saturated suction temp at which evaporator capacity is closest to condensing unit capacity (and then TD is room temp - that SST)?
Thanks in advance for your insights.
03-03-2009, 05:53 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Correct Evaporator TD Calculation
What is purpose of that estimation?
03-03-2009, 08:20 PM #3
Hi nike123. The purpose is to make sure the condensing unit to evaporator capacities are within acceptable range, to ensure correct humidity in the room. So for a storage freezer, a TD of 11 may be fine, but for a flower cooler, a TD of 8 or 9 would be more appropriate. Thanks in advance.
03-03-2009, 08:32 PM #4
PS: Those examples were in deg F... So the freezer TD was 6.1 deg K and the flower cooler was 4.4-5 deg K.
Flash gas calculation software
By nike123 in forum Tools and CalculatorsReplies: 4Last Post: 12-03-2009, 09:25 AM -
Calculation bypass buffer tank volume
By abbasi in forum New TechnologiesReplies: 3Last Post: 16-10-2008, 06:19 AM -
NH3 thermosiphon evaporator calculation
By cygbob in forum NH3Replies: 3Last Post: 27-11-2007, 10:00 AM -
how can i correct the dilution of the oil lubricant when i use hydrocarbons?
By mebluna in forum RefrigerantsReplies: 5Last Post: 11-07-2007, 03:06 AM -
Cooling load calculation
By raviperumal in forum Technical DiscussionsReplies: 6Last Post: 02-03-2007, 04:09 AM
