    Dec 2008
    China
    87
    Water velocity in water header
    Hello, guys!
    Do you know what velocity in water header is suitable?
    I'm talking about the water header of Air-Cooling and Dehumidifying Coils.
    From ASHRAE, we know the water velocity inside the tube is about 0.3-2.4m/s, but ASHRAE doesn't tell us about the velocity range of the water header. What's you opion?
    Thank you!
    11,025
    Re: Water velocity in water header
    I wont go into all the variations to this answer but will point you towards this e-book.
    http://www.haestad.com/library/books...tml/wwhelp.htm
    Click on the index and then the letter "V" for velocity, select What is Maximum.....
    Dec 2008
    China
    87
    This book is gorgeous!Thank you very much, Brian! I find my answer.
    It's a pity that I can't download this book.
    Nov 2010
    Germany
    120
    14
    Generally, the water velocity in header should be 0.2-0.3m/s. But,i use this kind of sizing only for main header. For instance, if you use the underfloor cooling with the manifolds, than it depends of the valves on it..For what do you need it exactly? Be careful regarding this stuff, it is just a piece of pipe but it has a great influence on the system..
  1. Water velocity in Shell and tube HE
    By wilsoncheung in forum Industrial
    Last Post: 07-04-2009, 07:59 PM
  2. Fact or Fiction
    By david.findlay in forum Fundamentals
    Last Post: 09-03-2009, 06:19 PM
  3. pure water from air
    Last Post: 26-02-2009, 12:25 PM
  4. what is suitable water flow velocity in Evaporator?
    By chistine in forum Commercial
    Last Post: 11-09-2006, 05:26 PM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
