Results 1 to 8 of 8
Thread: system design
    Jan 2009
    lleida
    47
    system design
    Hi everybody,
    I have a project for freezing foods
    this are the loads:
    660 kW at -45 ºC evaporating temperature
    600 kW at -28 ºC evaporating temperature
    No load for -10 ºC
    I was thinking first about two separate 2 stage systems with ammonia 4:1 (cold rooms).
    But I was told that this could be afford with some screws and economizer, only one stage compressors? (If I remember).
    I have seen some drawings in different threads (thank you Josip and US Iceman)
    But I have problems to adapt them to my needs.
    I know that cascade nh3/co2 could be a good option but I prefer think about it later.
    My question is if someone could give some explanations or drawings for a system that could achieve this with good technical aspects (optimization, reduced electric consumption...) and without a too large initial cost
    Thank you in advance!
    There's so long way to come...
    Nov 2006
    708
    23
    Re: system design
    I think you need some advice from Andy he he is a moderator of this site and I know he knows his beans I am sure he will point you in the right direction
    Jan 2009
    lleida
    47
    Re: system design
    Thank you Quality,
    I will wait for any comments that could help me.
    Any opinion will be helpful.
    I think that the different evaporation pressures are "too close" for a 2 stage "optimal" system.
    I mean that high stage compressors have to carry out a great compression ratio.
    But this will happen with all the different system options or not?.
    Jan 2009
    lleida
    47
    Re: system design
    I think i have understood the design system for this loads (-40-22 ºC) with just one stage screw compressors and economiser.
    economiser vessel gives gas flow to the screw port at the same pressure as gas-liquid saturated of -28 in order to feed the room at this temperature.
    The same vessel gives liquid flow to -28 rooms and receive it's gas-liquid sustion line, or is better to provide the system with another vessel in order to make this work (separately from economiser).
    thank you all for your help (in the case this finally arrives
    Mar 2005
    638
    Re: system design
    Optimal and low cost do not really go together.
    Just as an initial look at this, I would us an intermediate duty compressor around -10 dC (You need to vary this level for the best equipment fit between 019 dC and 0 dC). Parallel operation of the -45dC and the -28dC load into the -10 dC inlet compressor.
    I would keep it on all ammonia and notr bother with the CO2 cascade.
    Ken
    Jan 2009
    lleida
    47
    Re: system design
    Thank you, TXiceman
    I will work on that way
    Auckland
    74
    3,357
    37
    Re: system design
    At those refrig Kw verus temps., it will be not cheap, I can assure of that. Two stage cycle is efficient power wise.
    magoo
    Jan 2009
    lleida
    47
    Re: system design
    Thank you Magoo!
    I agree with you, we will wait for the customer's opinion!
  1. High Liquid Line Temperature
    By airefresco in forum Commercial
    Last Post: 11-02-2009, 04:36 PM
  2. Refrigeration system design
    By sachin9782 in forum Refrigerants
    Last Post: 19-11-2008, 07:27 PM
  3. Ammonia system design
    By ingherrera in forum NH3
    Last Post: 08-03-2007, 02:58 PM
  4. Co2 System Design
    By Brad Chen in forum Supermarket Refrigeration
    Last Post: 18-05-2006, 12:21 PM
