Results 1 to 2 of 2
    Jul 2007
    Kuwait
    7
    screw type compressor
    Dear All Members
    what is the advantage we can have if we use screw compressor in air condition as cooling result instead of normal compressor, Thank you in Advance
    amsahloul
    Somerset
    69
    4,697
    Re: screw type compressor
    Basically a screw is best suited for larger constant loads.
    If sized correctly they are extremely reliable and efficient.
    But their duty / working range is generally less flexible.
    Meaning for fluctuating loads over a large range.
    I would recommend other types.
    The design usage is paramount.
    But as a compressor they are as good or as bad.
    As any other type.
    Don't take these comments literally as there are ALLWAYS exceptions to the rule.
    For example.. Variable speed drive screw compressors cover a larger operating range.
    But usually have a larger footprint!
    I hope this has helped.
  1. Single screw compressor
    By dvtruc in forum Industrial Compressors
    Last Post: 28-01-2010, 03:40 PM
  2. parallel operation of screw compressor and piston type
    By cheikh ahmed in forum Fundamentals
    Last Post: 26-08-2008, 08:34 AM
  3. Oversize Piston in Open Type Recip. Compressor
    By imranmd in forum Commercial
    Last Post: 29-07-2007, 07:04 PM
  4. STAL SRM SCREW compressor
    By graeme ellis in forum Industrial Compressors
    Last Post: 15-03-2007, 02:01 AM
  5. Screw compressor vibration
    By jpumarada in forum Industrial Compressors
    Last Post: 26-04-2006, 01:43 PM
