    Oct 2008
    nz
    36
    checking compressors for wear
    hi there i was just wondering if somebody could give me some manufacturers recomended checks for wear on large industrial compressors after 5000,10000 & 20000 hours. thanks in advance
    Nov 2005
    New Zealand
    550
    Re: checking compressors for wear
    Quote Originally Posted by jbomba View Post
    Have you tried Google
    Norm
    My wife used to say you never listen to a word I say at least I think that what she said
    Oct 2008
    nz
    36
    yes i have, i need specifics for assignment it isnt covered in my study material
    Aug 2008
    ireland
    44
    15
    Screws every 5,000hrs, measure axial clearance, check shaft seal and alignment, slide movement,position indicator,check or change oil and filter, clean suction filter, motor bearings, capacity control, oil heater.
    50,000 oil separator filters, major overhaul.
    recips, every 5000, top overhaul, shaft seal and alignment, change oil and filter, loading gear, rings, float on shaft.
    10,000 big and small end bearings, mian and thrust beairngs.
    manufacturerers guidleines change with every installation due to maintenance and running.
    conditions.
    hope thats some help
    Pennsylvania
    113
    Here's what we do for an M&M compressor based on manufacturer's recommendations and our PSM program.
    Change Oil Charge 10,000 hours
    Change Oil Filter Elements 10,000 hours
    Clean Suction Strainer 10,000 hours
    Rebuild Compressor 25,000 hours
    Replace Oil Seperator Coalescing Filters 30,000 hours
    Quarterly Pressure Calibration 90 days
    Oil Analysis 180 days
    Grease Motor 270 days
    Annual Temperature Calibration 365 days
    Clean Compressor 365 days
    Vibration Analysis 365 days
    I would think any wear would show up in the oil & vibration analysis but with the very frequent rebuilds on these compressors you don't see a whole lot of issues.
  1. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  2. FES screw compressors
    By negmy13 in forum Technical Speculations
    Last Post: 08-08-2008, 07:40 AM
  3. Do we have some expert in replacing compressors
    By Zahid in forum Air Conditioning
    Last Post: 01-07-2008, 07:59 AM
