24-02-2009, 08:58 PM #1
Mitsubishi FDTWJ56HKXE2 - (Fan Motor)
I have a problem with a mitsubishi indoor unit (vr system) - model - fdtwj56hkxe2 - the fan motor rounds from the wrong way , instead of blowing air into the room from the louvers and sucking air from the filters beneath the fan motor , it blows air from the filters and sucks from the air louvers - the motor uses 1 phase of source power and i can't find what it is . The strange is that i have changed and the indoor pcb and the fan motor and it still works wrong .... Help ???
26-02-2009, 09:56 PM #2
Re: Mitsubishi FDTWJ56HKXE2 - (Fan Motor)
Check the fan capacitor. This will be plugged into the pcb and is either not connected or is itself faulty.
Brit
27-02-2009, 07:45 AM #3
definatly capacitor
27-02-2009, 01:32 PM #4
I have to agree, capacitor!
PP
03-03-2009, 06:30 PM #5
thanks a lot , i will check it out , i thought that it will probably be a capacitor problem , i putted on a new one but it didn't worked coeectly , i will try to change the connection of the capacitor . I saw to the pcb drawings that it has 4 - 5 options of capacitor installation .... Thanks a lot again !!!!Rasoulis M. From Hellas . . .
1ph motor instead of 3 ph motor.
By SPBDASAN in forum ElectricalReplies: 1Last Post: 20-02-2009, 07:56 AM -
help with testing 3 phase comp
By mat in forum FundamentalsReplies: 7Last Post: 19-01-2007, 09:03 AM -
locked rotor amps (LRA)
By vinod in forum Technical DiscussionsReplies: 16Last Post: 09-09-2006, 12:50 AM -
Fan motor over heating & Shuting down.
By Rookie in forum DomesticReplies: 15Last Post: 30-06-2005, 11:21 PM
