    niiiksk's Avatar
    niiiksk Guest
    Exclamation HELP!! Candy CFMF 236A fridge freezing.
    Hi can anyone help me Candy CFMF 236A freezing fridge unit, milk food etc i have change module pcb 97922579 and no difference still freezing, i have just recieved fridge sensor 97061619 but not sure how to fit please can you help or advise if fault known Thankyou Nick. asap please.
    Dec 2008
    UAE
    42
    171
    Re: HELP!! Candy CFMF 236A fridge freezing.
    Please write your problem in detail as not much can be concluded.
    niiiksk's Avatar
    niiiksk Guest
    Thought it was pretty obvious! its a candy f/freezer and fridge freezers everything! changed pcb and still freezers ? any help advice welcome. Nick.
    May 2006
    Shropshire
    56
    34
    Hi Niiiksk - Your post reads fine to me....
    I have an answer for you, but it is not great news.
    I deal with the same machines -over-running and freezing everything in fridge. i check the gas charge and replaced PCB modules but still sub-zero in fridge....
    I'm told by another engineer that the fridge-section temp-sensor needs to be changed, and now for bad bit! THESE SENSORS ARE FOAMED IN PLACE AT FACTORY and cannot be changed !!
    ......Unless any of the 'Candy guys' reading know how ?!
    regards AH
    (Dreadnought Fridge repair Co
  1. Candy Fridge Freezer Help
    By matthewprince in forum Domestic
    Last Post: 27-06-2010, 08:11 PM
  2. Replies: 1
    Last Post: 07-09-2008, 11:16 PM
  3. Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
    By sumnerpa in forum Trouble Shooting
    Last Post: 19-08-2008, 03:16 PM
  4. Replies: 4
    Last Post: 27-05-2008, 01:03 AM
