Thread: Pull down temp new cold store
Hybrid View
21-02-2009, 10:51 PM #1
Appreciate if anyone give their opinion on whats the best way to pull the temperature down on a brand new cold storage facility.
Room temperature today is @ +25c under construction
End result needed -22c
My idea is
Days 1-3 +4c
Days 4-10 +2c
Days 11-15 0c
From here drop 2 to 3 deg per day until room temperature required achieved.
During the pull down authorized access will be controlled
22-02-2009, 01:34 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Pull down temp new cold store
I suggest 5K per day except between +2°C and -2°C temperature, where it should be slower, for example 2K per day. That is how I was taught. But, that could depend on size. Bigger the size, slower shake-down.
22-02-2009, 09:42 PM #3
The size of the room is 16000 pallets
24-03-2009, 02:14 PM #4
We are doing big walk in coolers and freezer since 50 years ago
we had experience in this subjet and solve the problems cooling as low as posible. Normally 10 to 15 days
A big camera problem is if cooling is quick, the superficial superficie is soft and when the circulation of lift truck start, there is a lot of powder. . We use in the concrete and aerator and we applied a special liquid over the surface, for close the cell. If you are interesed we can send the namecomponents that our supplier included in the concrete, also the name of components of sealers,
Paint over superficie is lost time.
Normally we use do a very smooth surface using a helicopter
Luisarce
Arceyasoc@arnet.com.ar
Construction of new Cold Store
By lalthomas in forum System OptimizationReplies: 23Last Post: 19-04-2009, 02:01 AM -
Expansion Joints in the cold store floor
By smpsmp45 in forum NH3Replies: 2Last Post: 17-05-2008, 07:47 AM -
cold room temp & the product temp
By smpsmp45 in forum NH3Replies: 9Last Post: 21-09-2007, 11:46 PM -
Recip Vs Scroll compressors for Low temp cold store
By smpsmp45 in forum Industrial CompressorsReplies: 9Last Post: 23-06-2007, 12:47 PM
