    tokichaw's Avatar
    tokichaw Guest
    Question Research institute cold room
    How do you design cold rooms for research institutes?
    11,025
    Re: Research institute cold room
    The design of the cold room depends on what they want to store in it.
    [Copied from Nevgee post] If you are not familiar with calculating heat loads for cold rooms, such as fabric gains, electrical inputs, product load (sensible Latent and respiratory) , occupancy gains, running times, defrost inputs etc then it's probably better that you use a software program.
    Go to this site download their coolpack software ..
    http://www.et.web.mek.dtu.dk/Coolpack/UK/About.html
    go to download ... Run the software ...go to Cooltools design
    open cooling demand
    You will find an easy to use cold room load calculation program. Which should help you. If you still wish to do it long hand then use the software as a check.
    tokichaw's Avatar
    tokichaw Guest
    Question Re: Research institute cold room
    Brian,
    thank you!
    I will look into the Coolpack software.
    Here is the detail about my situation.
    I am assigned to finish an already started cold room erection(installation). Currently the walls are finished with cement. The ceiling is made from chip wood. We have a complete set of refrigeration machine applicable to simple box rooms like ours and It just needs a small window through which the machine breathes its cold air. Styrofoams are also bought.
    Now, I think I should put the Styrofoams on the walls and ceilings and then place sheet metal on it although I am just not sure if this sounds right. In addition, I would like to have advice on how to put these materials together to make the cold room temperature tight.
    Thanks a lot.
  1. Cold room floor
    By Andy AC in forum Commercial
    Last Post: 19-02-2009, 04:26 PM
  2. Cold room panels
    By LLCooLJ in forum Commercial
    Last Post: 07-04-2008, 04:18 PM
  3. cold room
    By CHILLED4 in forum Trouble Shooting
    Last Post: 16-11-2007, 11:44 PM
  4. Installation of cold room
    By Josip in forum Legal-Business-Marketing
    Last Post: 12-03-2006, 09:20 PM
