Thread: Mortuary Fridge
    Apr 2001
    2,099
    27
    Mortuary Fridge
    I have a requirement for a small mortuary fridge capable of holding 3 bodies.
    Appreciate any guidance on UK based suppliers with contact numbers.
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Aug 2001
    1,046
    Re: Mortuary Fridge
    Abe,
    If you do a UK Google 'Mortuary equipment', you'll find specialist suppliers listed. Coolers come in all sizes and capacities, but you'll need to check the holding times and temperatures against current regulations.
    Kenyon's used to be a prominent company as I recall, in Manchester, I believe, there are others.. but things have moved on a lot since I was on the tools.
    One thing to consider if you have guys on the tools is the perceived risk for those fitters working on mortuary coolers in the wild, as it were.
    I think that there are some mandatory precautions that now includes guarding against HIV, hepatitis etc and other contact-borne diseases.
    Jul 2006
    norfolk
    737
    Re: Mortuary Fridge
    LEC do them
    www.reagecon.com/ReageconOneCMS/CMS/Company/Reagecon/Uploads/Lec_commercial_appliances.pdf
    Nov 2005
    New Zealand
    550
    Re: Mortuary Fridge
    Quote Originally Posted by Abe View Post
    Hi Abe Try this
    http://www.tekmed.com.au/morgue_cooler.html
    Regards Norm
    Feb 2006
    derbyshire
    610
    Re: Mortuary Fridge
    stancold at bristol have done them for me in the past,if you get my drift. the box is cheap but the racking and trays are not, its only meat and short term untill the undertaker comes so 1 deg C is fine,no heaters needed,just run the fans continious,the ones i have worked on run 1-4 C, depending on the operator,there are kit type ones but not sure who sells them.
    Feb 2009
    Re: Mortuary Fridge
    One thing to consider is how to maintain a unit and easy access to parts.
    Ok story for ya: As a 17y 2nd year, i was paced on the slab and pushed into a body fridge 10 holding capacity, 9 in the box!
    After removing the evap cover with door shut cause the boys thought it would be a laugh! torch in mouth , oh god the smell!! Hitting the cover to remove it yields this green slime that splatted me on the face!
    Then me kicking trying to get out! great laugh for the boys, till they let me out, i come out of that box like ferrell cat swinging!
    After removing my work mates eye ball from my finger! i washed my face under a wall mounted urn, and had more needles than i care to remember!
    Moral of the story: Maintenance access!
    Feb 2006
    derbyshire
    610
    Re: Mortuary Fridge
    not nice i hate things like that now,allthough when younger i might have been a culprit the crap you go through when a apprentice.
    i agree to making the parts easy to get at as gas leaks are allways inside, so i mount the TEV on the outside directly above the evap,solder type,not much you can do about the probes apart from put them just inside the door.
    ndumitru's Avatar
    ndumitru Guest
    Re: Mortuary Fridge
    lec-medical.co.uk
    Jul 2008
    uk
    150
    Re: Mortuary Fridge
    Williams refrigeration supply mortuary rooms as well.
    http://www.williams-refrigeration.com/index.asp
    Feb 2009
    telford
    2,092
    33
    Re: Mortuary Fridge
    now i know the job is dead ho ho ,only worked on two of these at undertakers ,i still shiver thinking about them
    prossi's Avatar
    prossi Guest
    Re: Mortuary Fridge
    Hi Abe WJ Kenyon in Manchester supply these on a world wide basis.. great company to deal with.
  1. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  2. John Lewis, fridge warm but freeze ok
    By netingit in forum Domestic
    Last Post: 21-08-2008, 01:23 AM
  3. Should dial change fridge temperature??
    By Trisha in forum Trouble Shooting
    Last Post: 12-02-2007, 08:00 PM
  4. help- my bar fridge is wacko?!
    By ben in forum Trouble Shooting
    Last Post: 25-01-2002, 12:06 AM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
