Thread: Multi-Hertz compressor
18-02-2009, 10:51 AM #1
Our company is starting to supply our refrigerated units with 50hz compressors. Is there a compressor that has the ability to switch from 60hz to 50hz and vice versa or is there an adapter?
18-02-2009, 12:20 PM #2
Re: Multi-Hertz compressor
It depends on the voltage. A 60Hz, 460V compressor should run happily on 380-400V 50Hz. 1-phase compressors is probably harder to make dual Hz versions of.
18-02-2009, 09:23 PM #3
As long as v/f is constant, no problem for the motor.
18-02-2009, 11:05 PM #4
We typically use 220v/60hz and 120v/60hz compressors.
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Help with multi compressor pack systems!!!!
By dez in forum Chit Chat & Service StoriesReplies: 1Last Post: 27-11-2008, 01:09 AM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
RHOSS multi unit compressor dead
By cool#9 in forum Air ConditioningReplies: 4Last Post: 15-06-2007, 09:19 PM -
Mitsi City Multi Compressor Death
By aeb200 in forum Air ConditioningReplies: 4Last Post: 16-11-2005, 09:10 AM
