    Feb 2009
    NOTTINGHAM
    9
    Mitsubishi p5 ygaa
    HI ALL ANY ADVICE ?
    Seem to have blockage on system have discharge pressure of 80 psi low and high pressure going into vacuum freezing out of lev from gauze. Have taken of lev and surrounding pipes cant find blockage all this after compressor failure. also have same problem on another mitsubisji system. found some sludge in the gauze near lev but nothing exciting any suggestions
    11,025
    Re: Mitsubishi p5 ygaa
    Have you checked for any gauze at the evaporator connection.
    Jan 2007
    82
    From memory there is a gauze strainer within/before the distributor "cone" -on Mitsu' cassettes anyway. I had one block many years ago on an R22 split with a long pipe run- obvioulsy no OFN purging during install by our subbies!
    "I'm anaspeptic, frasmotic, even compunctuous to have caused you such pericombobulation."
  1. [Ask] Mitsubishi rotary compressor
    By felixfab_93 in forum Refrigeration Books
    Last Post: 18-12-2008, 10:48 AM
  2. Mitsubishi Electric VRF help
    By marc5180 in forum Air Conditioning
    Last Post: 04-11-2008, 09:40 AM
  3. Mitsubishi Light Truck Refrigeration
    By Mastercool in forum Transport
    Last Post: 23-11-2007, 06:15 AM
  4. mitsubishi city multi fault code
    By robin r33 gtr in forum Air Conditioning
    Last Post: 05-11-2007, 10:23 PM
  5. Mitsubishi compressor lock
    Last Post: 08-10-2007, 05:48 PM
