    Feb 2009
    Malaysia
    43
    5
    Question How to check leakage?
    Leakage in inner body for chest freezer is hard to detect. any suggestion or easy way to check leakage in evaporator, accumulator or condenser?
    Feb 2009
    Malaysia
    43
    5
    Re: How to check leakage?
    any one want to help solve my proble?
    Split Croatia
    6,151
    Quote Originally Posted by syaful View Post
    Be patient, 3 min of waiting and immediate sniveling is pretty much childish for someone with your age.
    Call your helpline for fast service.
    11,025
    Be more patient, this is not a telephone help line forum.
    The only way that I know of is to destroy the chest to gain access to the coils then pressure test with nitrogen.
    zulkarnain's Avatar
    zulkarnain Guest
    Recommend change new air-cond.
    Feb 2009
    telford
    2,092
    33
    seal off condensing section and pressure test it ,then pressure test evaporator section easy
    africaguy's Avatar
    africaguy Guest
    Normaly they leak in the bottom of the box due to corrosion on the pipes. Remove the bottom insulation and pressurise the unit and check. 99% of the time it is not viable to repair them. It will work out cheaper in the long run to just buy a new one.
  1. Installation of NRVS check valves
    By Josip in forum NH3
    Last Post: 02-12-2008, 01:33 PM
  2. Replies: 3
    Last Post: 17-07-2008, 01:42 AM
  3. Air conditioning maintenance procedure
    By Andy T in forum Air Conditioning
    Last Post: 27-05-2006, 06:57 PM
  4. Double check needed
    By Latte in forum Trouble Shooting
    Last Post: 11-08-2004, 12:46 PM
  5. Compressor Check for locked rotor voltage
    By shogun7 in forum Trouble Shooting
    Last Post: 04-04-2004, 12:44 AM
