17-02-2009, 03:25 AM #1
centrifugal chiller VS absorption chiller
Is there anyone who know about advantages and disadvantages absorpton chiller compare with centrifugal chiller ?
17-02-2009, 04:51 AM #2
Re: centrifugal chiller VS absorption chiller
Absorption chillers are generally only used where there is waste heat from another process available. Such as Tri/Co Generation plants, where there is waste heat from power generators. So you wouldn't use an absorption chiller for a hirise building unless it was generating its own power. I have seen absorption chillers in 2 hospitals, 1 was a 7.2 mW Trane.
20-02-2009, 11:40 PM #3
Disadvantage points are Low COP,Higher Initial Cost,Bigger Footprint/Height/Weight,and Corrosive Absorbent. Advantageous points are Waste Heat Application,Small Power Consumption,Ozone Safe & CFC Free,and Low Noise & Vibration. President Obama might love this system with CHP for his Green Plan.
01-03-2009, 12:28 PM #4
Centrifugal chillers are Electrical energy Motor driven where as Vapour Absorption uses Steam or direct fired source of heat energy.
Vapour absorption has low COP but considering the various inputs right from Power plant to end use it may work out economical.
Bureau of Energy Efficiency(BEE) of Government of India suggests vapour absorption machines are suggested only where surplus steam like Paper mills. Cogen power plants where steam or hot water is available for using in Vapour absorption machine.
Ice rink with Absorption chiller
By mjsnow in forum Technical SpeculationsReplies: 10Last Post: 21-09-2009, 07:08 AM -
Absorption Chiller VS Mech. Chiller
By Intern in forum IndustrialReplies: 20Last Post: 30-05-2009, 08:31 AM -
Pro and Cons of open sharfted centrifugal chiller
By THE WOMBAT in forum FundamentalsReplies: 5Last Post: 06-02-2009, 10:11 AM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM -
R11 Centrifugal Chiller Oil Problem
By iceman007 in forum Trouble ShootingReplies: 8Last Post: 17-02-2008, 02:14 AM
