Thread: Sullair C Series and CB Series
Hybrid View
17-02-2009, 02:39 AM #1
Hi - Can any one provide me with or direct me to
(1) part load performance curves for Sullair C Series and/or Sullair CB series ammonia compressors.
(2) Refrigeration capacity data for the C Series and CB series
(3) experiences with these machines ie. reliability, efficiency, are they easy to work on?
Thanks in advance
17-02-2009, 08:11 PM #2
Re: Sullair C Series and CB Series
You might want to contact this member, Sullair Refrig, he might be able to help you.
18-02-2009, 06:16 AM #3
18-02-2009, 09:44 PM #4
If you would like to contact me at dan@midstatesrefrig.com with Sullair model number and operating conditions we can provide the desired information from an old DOS program. The CB series was produced from the mid 70's until about the mid 80's when it was changed to the A series.
As far as reliability the C series line was first put into operation in about 1972 and were packaged by Sullair Refrigeration until 1997. There are still many packages in use throughout the world. Sullair makes only the screw compressors today. Efficiency, a screw is most efficient at full load. I only work on Sullair Refrigeration compressors.
New to RE and needing Daikin Help
By Owen in forum Air ConditioningReplies: 20Last Post: 25-09-2008, 06:55 PM -
Defrost Elements in series?
By Drew in forum ElectricalReplies: 8Last Post: 26-06-2008, 07:28 AM -
2 chillers in series
By giovanni in forum Technical DiscussionsReplies: 18Last Post: 23-06-2007, 07:08 AM -
VRV fault
By Jase in forum Air ConditioningReplies: 10Last Post: 16-05-2007, 08:21 PM -
Fujitsu J series
By dunty in forum Air ConditioningReplies: 2Last Post: 21-09-2006, 02:06 PM
