Thread: Vi rule
15-02-2009, 07:48 AM #1
Vi rule
I have question about Vi in screw compressor.
I want to know why discharge temperature increase if i use a compressor with higher Vi
15-02-2009, 01:31 PM #2
Re: Vi rule
VI is a subject that needs a bit of study to understand.
Overcompression or Undercompression occurs when the VI is not correct.
I would suggest that you read this article. I refer to it often.
http://www.petroassist.com/Tech%20Kn...ompressors.pdf
Thank you Mr. Pillis (The author of the article)
16-02-2009, 05:00 PM #3
Re: Vi rule
NH3LVR Thanks for the link C.D.
16-02-2009, 06:35 PM #4
Re: Vi rule
If the volume ratio number (the number associated with the Vi) is higher than the optimum Vi, the compressor is over-compressing the gas. This causes the higher discharge temperature.
16-02-2009, 08:49 PM #5
Re: Vi rule
Like US Iceman said...more compression pushes the discharge temperature up. Look at the Idael Gas Laws.
Ken
17-02-2009, 06:36 AM #6
Re: Vi rule
Hi members
thanks for your complete answers.
Rule of Thumb in HVAC Industry
By smpsmp45 in forum FundamentalsReplies: 6Last Post: 13-10-2011, 12:40 PM -
Thumb rule for belt driven compressor - Power loss
By smpsmp45 in forum NH3Replies: 4Last Post: 27-09-2007, 09:26 AM -
404A head pressure to ambient rule of thumb
By kengineering in forum RefrigerantsReplies: 22Last Post: 08-05-2007, 10:40 PM -
Rule of Thumb on Refrigerant Amount
By rickmor in forum RefrigerantsReplies: 7Last Post: 19-12-2005, 11:18 AM -
condensing temp rule of thumb
By angryk in forum FundamentalsReplies: 8Last Post: 14-03-2003, 04:00 AM
