Thread: 220-240V 50hz
    keyserstaf's Avatar
    keyserstaf Guest
    220-240V 50hz
    A compresssor rated at 220-240V 50Hz how will the same operate connected to a 208V 60Hz service?
    Jul 2007
    Australia
    1,845
    Re: 220-240V 50hz
    It will run faster and draw more current.
    bashirac's Avatar
    bashirac Guest
    Re: 220-240V 50hz
    As you know the speed of the motor is 120*frequancy over the number of poles that is why it will run quit good
    495
    21
    Re: 220-240V 50hz
    hi there a 50hz rated motor will get very hot and burn out because it has less copper wire turns in the stator, however there are lots stators designed to run on both 50/60 hertz check the ticket on the stator it normally says on it.
    Dec 2008
    California
    58
    14
    Re: 220-240V 50hz
    First of all it's 20 volts lower and secondly shouldnt the 60 hz create more inductive reactance and lower the current? You ever seen how small the steels on a 400 hz motor are?
    May 2008
    66
    802
    Re: 220-240V 50hz
    hopefully its not a inverter system,because the inverter pcb board will break dawn.
    its not only the compressor but the complete electrical system you shoult watch.
    Ice
  1. 110v 60hz in a country w/ 220v 50hz
    By dkupinsky in forum Technical Speculations
    Last Post: 02-08-2010, 03:20 PM
  2. 50HZ compressor on a 60HZ circuit
    By dan wong in forum Technical Speculations
    Last Post: 13-06-2009, 05:52 PM
  3. Replies: 31
    Last Post: 21-06-2008, 11:53 PM
  4. 240v to 12v Transformer
    By 4Qman in forum Electrical
    Last Post: 31-07-2007, 12:42 PM
  5. 50Hz vs. 60Hz, okay to run at slower frequency?
    By pezagent in forum Commercial
    Last Post: 26-05-2003, 07:48 PM
