Thread: Mistral MSS15
12-02-2009, 07:30 PM #1
Mistral MSS15
A customer has transported a used split system heat pump ac unit from Oz to the UK and wants me to fit it.
No problem but on the outdoor unit there are the normal terminals for the 5 core interconnecting cables but also there are two cables still connected marked R1 & R2 and am not sure what they do, can't see a diagram on the outdoor unit only on the indoor which doesn't mention them.
Can't find a diagram online.
Anyone come across these ?
12-02-2009, 08:08 PM #2
Re: Mistral MSS15
Using the amazing power of Google, the first hit gave me the Operating Instructions for your unit.
You may download the file from here...
http://www.clipsal.com.au/trade/__data/page/81/W670.pdf
Sadly, I don't know whether it will help you or not. The R terminals have a plug on them - great eh?Brian - Newton Abbot, Devon, UK
12-02-2009, 09:03 PM #3
Re: Mistral MSS15
Thanks,I should have mentioned I'd got that,it does show the two connectors but no info on their function.
12-02-2009, 09:22 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Mistral MSS15
Since this is old R22 unit I suppose that they are for outdoor unit temperature sensor (defrost) connection with indoor unit. Usually they are delivered wit cable which have connector on one side (indoor) but they are not polarized and could be connected with simple wire terminal.
12-02-2009, 10:46 PM #5
Re: Mistral MSS15
Yes, most likely its a thermister in the outdoor that is connected to the indoor PCB.
12-02-2009, 11:31 PM #6
Re: Mistral MSS15
Thks for that.
Help Needed - Fridge not working on Hotpoint Mistral FF91
By karlaskie in forum DomesticReplies: 18Last Post: 13-06-2011, 11:49 PM -
Hotpoint Mistral: copper dust (?) inside freezer
By pollypom in forum DomesticReplies: 4Last Post: 27-04-2008, 12:44 PM -
Hotpoint Mistral Plus
By Bobby Ewing in forum DomesticReplies: 5Last Post: 05-01-2008, 11:35 AM -
Changing interior bulb wipes out my H/point Mistral f/freezer
By mikeee in forum DomesticReplies: 4Last Post: 13-01-2007, 04:08 PM -
By Abe in forum DomesticReplies: 14Last Post: 26-07-2006, 07:20 PM
