Results 1 to 15 of 15
Thread: Recoverd Gas
    Feb 2009
    N. Ireland
    37
    11
    Recoverd Gas
    I was recovering gas from a r12 system recently wile carrying out a condenser change, and unfortunatly had no recovery bottles, so i filled the refrigerant into a binliner, when i returned to charge the system the gas had escaped, what should I do?
    Thanks for all advice in advance
    Aug 2001
    1,046
    Re: Recoverd Gas
    You must have had a hole in the bin-bag.
    It won't be far away. You'll probably find that it's under the floor boards.
    Take up all the floor boards, one at a time, and carefully collect it all with a vacuum cleaner back into the bin bag.
    Try to get a photo of it and post it here - the engineers are always keen to see how it can be done.
    Dec 2006
    Mansfield
    57
    231
    Re: Recoverd Gas
    Also, make sure the vacuum cleaner is a dyson, these have an anti fluffer valve so no gas can escape, you san then attach guages to the removable cylinder and re charge it into the system.
    PP
    Nov 2006
    708
    23
    Re: Recoverd Gas
    I never noticed before but I have just looked and found a 1/4 flare connection on my DC01 thanks for the advice p p
    Sep 2008
    427
    Re: Recoverd Gas
    Maybe the safety valve lifted, I`d recommend fitting a new one and getting the bin line pressure tested
    Aug 2004
    744
    Re: Recoverd Gas
    It's only R12, the good old U, S of A, China and India loose $hit3 loads of it every year.
    Don't worry
    Eggs
    Feb 2009
    N. Ireland
    37
    11
    Re: Recoverd Gas
    Iv now found that the henry is a perfect vacume cleaner for a refrigeration engineer! it dubbles as a vacume pump!
    3,856
    Re: Recoverd Gas
    I've got one of those dewalt ones that uses tool batteries so i can vac out if i've drilled through the mains tails again
    Aug 2009
    85
    15
    Re: Recoverd Gas
    Quote Originally Posted by Tullyvernon View Post
    god you are so funny .
    AirconGuy's Avatar
    AirconGuy Guest
    Re: Recoverd Gas
    THey also double as a trolley to carry condensing units on (110kg henry took it no probs)
    And i have seen one (same one in fact) dropped 2 stories and it survived.
    Henry is hardcore
    Apr 2009
    Singapore
    48
    Re: Recoverd Gas
    lucky u :>
    Spencer ma.
    108
    Re: Recoverd Gas
    Wow funny post I did need to translate it on Wikipedia to U.S.A. speak to find what a binliner is A bin bag, garbage bag, trash bag, refuse sack, can liner (American English), swag sack or bin liner (British English) is a disposable bag used to contain rubbish. Such bags are useful to line the insides of waste containers to prevent the insides of the receptacle from becoming coated in waste material. funny stuff!
    (It's only R12, the good old U, S of A, China and India loose $hit3 loads of it every year.)
    Don't worry
    Eggs
    You are right we are the worst on on.
    fridgy's Avatar
    fridgy Guest
    Re: Recoverd Gas
    hahahahahaha
    Mar 2007
    manchester
    63
    Re: Recoverd Gas
    i saw an engineer mopping r12 up with a rag- yes really he "dropped" something on the pipe and soaked up the gas with a cloth. He doesnt get out much.
    Apr 2010
    Delhi
    67
    26
    Re: Recoverd Gas
    Can you explain how you recover the gas completely.
    Do you use a rcovery system?
