Thread: Connection
06-02-2009, 10:29 AM #1
Connection
To enable checking of pressures and avoid the loss of gass, I was looking to fit either electronic pressure transducer or clycerine filled gauge to the hp and lp service valve connections or at the evaporator - split units. Are the service valve conections 1/4 sae flared.
06-02-2009, 04:50 PM #2
Re: Connection
It is a Copeland Compresser ZF24K4E
10-02-2009, 05:58 PM #3
Re: Connection
You may look at the manufacturer web site for product information. Here is the llink.
https://opi.emersonclimate.com/was.e...web/OPIServlet. You will have to register to get access to all product information.
flow switch connection
By afeef in forum The Trail of TearsReplies: 18Last Post: 23-12-2009, 06:55 PM -
stop-leak for threaded connection on NH3?
By Buckiesr in forum IndustrialReplies: 15Last Post: 21-01-2008, 02:38 AM -
Fire - run capacitor, high resistance connection?
By Kenedt in forum Technical DiscussionsReplies: 13Last Post: 13-08-2007, 07:07 PM -
proper connection of a Water cooled plant
By The MG Pony in forum FundamentalsReplies: 7Last Post: 30-05-2007, 10:49 PM -
connection cable for spilt unit
By afeef in forum ElectricalReplies: 4Last Post: 10-04-2007, 05:33 PM
