Thread: Frick Plus Panel
05-02-2009, 03:01 PM #1
Frick Plus Panel
Hi Guys
I'm working with an old Frick plus panel with a Rev C board in it, operating an RWB II 222. I've heard that you can reset the bios on these boards by jumping across one pin from U4 to a pin on U5 ( Eproms ). Does anyone know which pins to jump out? I would hate to get it wrong and burn out the chips.
J.D
05-02-2009, 03:04 PM #2
Re: Frick Plus Panel
I have never heard of this; but I am sure there is someone on RE who can give you a definite answer.
05-02-2009, 03:37 PM #3
Microprocessor EPROM memory I/C chips are located inside
the microprocessor console on the SBC board. A special
tool is required to remove these chips to lessen the
chance of damaging them (See Troubleshooting The
Microprocessor). The procedure to replace EPROM memory
chips is outlined below:
1. Shut off control power.
2. Remove the microprocessor console cover.
3. Using a chip extraction tool, remove the old EPROM chips
from the SBC board. Pay particular attention to the orientation
of the notch on the end of the chip; then install new chip
with the notch in the same position. NOTE: The chip labeled
4 must be inserted into socket U4 and the chip
labeled 5 must be inserted into socket U5.
05-02-2009, 05:44 PM #4
Hello jd send me your email address and i post you the litrature
Clips + sliders to attach a wood panel door to a fridge door.
By geniescience in forum DomesticReplies: 3Last Post: 13-12-2008, 01:15 AM -
Ammonia Circulation rate - by Frick/ Vitler
By smpsmp45 in forum NH3Replies: 12Last Post: 16-06-2008, 10:06 AM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM -
Frick Quantum Panel
By LEE40 in forum Trouble ShootingReplies: 4Last Post: 27-03-2008, 05:24 PM -
Frick Micro Control Panel Problem
By derfriguy in forum New to REReplies: 7Last Post: 11-04-2007, 07:45 AM
