Results 1 to 9 of 9
    Feb 2008
    Lima - Peru
    41
    49
    Sabroe SMC 16-100 Help me please
    Hi Guys:
    Somebody has tables where i can find the capacity of the reciprocanting compressor SABROE 16-100.
    Best Regards.
    Somerset
    69
    4,698
    Re: Sabroe SMC 16-100 Help me please
    Quote Originally Posted by luissandoval View Post
    Hi Guys:
    Best Regards.
    Hope the attached helps
    Jul 2007
    Czech
    61
    373
    -40/-10 135kW
    -10/+30 526kW
    Feb 2008
    Lima - Peru
    41
    49
    Tanks josef, could you give me the capacity of the reciprocanting compressor SABROE 12-100 please? Where do you find these capacities????
    Jul 2007
    Czech
    61
    373
    -10/+30°C 262kW
    Apr 2008
    The Netherlands
    49
    67
    Hi louisssandoval,
    The thread is already 2 weeks old but here is another idea.
    If your looking for answers on SABROE compressors, try www.sabroe.com
    Greetings,
    Bart.
    mr.Widitama's Avatar
    mr.Widitama Guest
    Dear all,
    Is "SMC 12-100" equal to 'SMC 112S" ?
    thank u
    Jul 2007
    Czech
    61
    373
    Type S has an 80 mm piston stroke and is
    used with all approved refrigerants.
    Type L has a 100 mm piston stroke and is
    Type E has a 120 mm piston stroke and is
    used only in connection with R717. The
    compressor has 50% more capacity than
    type S.
    Josef.
    Nov 2010
    Lincoln
    5
    Hi Guys:
    Best Regards.
    I can get you swept volume what speed is the compressor running at ?
    capacity in KW will depend on running conditions
  1. Sabroe 202 LM
    By nh3wizard in forum Industrial Compressors
    Last Post: 10-03-2011, 05:35 PM
  2. Sabroe SMC 108E
    By negmy13 in forum Refrigeration Books
    Last Post: 05-03-2009, 03:08 PM
  3. sabroe water chiller
    By dill in forum Air Conditioning
    Last Post: 17-12-2006, 07:26 PM
  4. Sabroe oil filters..grumble, grumble, grumble...
    By SteveDixey in forum Industrial Compressors
    Last Post: 25-12-2005, 07:49 PM
