    GCoastone's Avatar
    GCoastone Guest
    Ice Machine storage
    What's the best way to shut down and prepare a commercial ice maker for storage.
    Is this desirable?
    Are there risks associated with not using these machines for periods of time?
    Would you in your opinion shut off and not use an ice maker or would you allow it to keep full durring long (3 month) periods of little or no use?
    Apr 2008
    canada
    75
    94
    Re: Ice Machine storage
    B"H
    What type of ice machine?
    GCoastone's Avatar
    GCoastone Guest
    Hoshizaki KM-2000S3 is a common model we use.
    I'm asking, because several of our sites have multiple machines, and when business decreases, the question was asked if it would save energy to shut these units off 2 to 3 months as needed.
    11,025
    I would have thought that you should be able to shut the machines down without problem.
    Make sure that the water ways are clear and clean, descale first perhaps. Drain all water from machine, keep air gaps around any doors/flaps to aid ventilation.
    http://www.hoshizakiamerica.com/tech...ll/Tips106.pdf
    GCoastone's Avatar
    GCoastone Guest
    would you foresee any problems with compressor, condensor, or refrig system seals or whatnot?
    Apr 2010
    Lake City Florida
    64
    4
    And that is why I use the XL1800 Ice Machine from Bag of Ice
    AceParkle's Avatar
    AceParkle Guest
    If you want to shut off your ice maker always disconnect the ice maker if you do not use it and always remove the leftover ice cubes. The important is you know how to maintain the cleanliness and proper use of it. In order to avoid the risks or problems in future.
  1. Replies: 15
    Last Post: 02-01-2011, 01:26 AM
  2. elmeco slushy machine
    By Temprite in forum Commercial
    Last Post: 14-09-2008, 08:58 AM
  3. No. of temperature sensors required in cold storage?
    By dipankarmohanty in forum Technical Speculations
    Last Post: 14-03-2008, 07:45 AM
  4. Atlas Slice Ice Machine
    By Glide in forum Trouble Shooting
    Last Post: 27-07-2007, 07:56 AM
  5. Cattabriga Ice Cream Machine
    By Abe in forum Trouble Shooting
    Last Post: 26-04-2003, 01:06 PM
