Thread: vaccum cooling
    495
    21
    vaccum cooling
    Hello guys i saw something which was new to me and ive been in the game for about 15 years and thought it was very interesting. its a big industrial plant which packs vegetables and these vegetables go inside a chamber and the vacc pumps boil the mositure of and make them dry and cool in a very short time,and then the fridge comps start up and cool the vapour and dry the air so the mositure doesnt get back to the vacc pumps ,because they cost more then 20k pounds and you have a air compressor opening and closing the valves for vacc lines . are there alot of these systems about or is there an alternative and hoe effective is it
    Apr 2006
    55
    1,908
    30
    Re: vaccum cooling
    Similar setup is used for freeze dried products such as coffee
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: vaccum cooling
    I worked on one and they are very rare. But as far as food preservation goes I think they are the best for drying food quickly to reduce the amont of cellular rupture and slow down osmosis (transfer of fluids between cells. Check out vapor pressure defficite ( hope I spelt that right )
    Feb 2008
    Saudi Arabia
    52
    69
    Re: vaccum cooling
    Hi All,
    We are working on new project in our food factory here in Saudi - Riyadh and I am in need to have any information. please help
    khalid.alhasan@gmail.com
    Feb 2008
    Buenos Aires
    8
    Re: vaccum cooling
    In Argentina vaccum cooling is used for post harvest of green vegetables with leaves bigs as lettuce, we had good experience in this equipments. With a lost of water of 2 or 3% and a refrigeration equipment of 20/30Hp we are cooling 4 pallets cith boxes of lettuce
    Also we had experiences in al post havest process for vegetales and fruits
    Luisarceweb page www(dot)arceyasociados(dot)com(dot)ar
    Sep 2008
    Portsmouth,England
    59
    Re: vaccum cooling
    Good day one and all.
    I work on a few vac coolers. They are used to rapidly cool veg with high water content (lettuce, celery etc) from field ambiant to fridge temp. Most of the supermarkets DEMMAND that all produce is at +5C within 2 hours of picking.
  1. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  2. Energy saving Glycol filled dry cooler circuits
    By Jasper in forum Technical Discussions
    Last Post: 19-06-2008, 02:18 PM
  3. Compressor loading, cooling, and range of operation.
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
